2.00 mole of an ideal, monatomic gas
  • Context: Chemistry
  • Thread starter Thread starter nkk2008
    Gas Mole
The discussion revolves around a thermodynamic problem involving 2.00 moles of an ideal, monatomic gas undergoing an irreversible adiabatic expansion against a constant external pressure. Participants are exploring how to calculate changes in entropy and Gibbs free energy for the process, while seeking clarification on the implications of the hints provided in the problem statement.
  • Homework-related
  • One participant seeks guidance on how to interpret the hint regarding breaking the expansion into two steps to calculate delta S for the system.
  • Another participant suggests that standard thermodynamic equations apply primarily to equilibrium processes and proposes splitting the irreversible process into multiple reversible parts to make the calculations tractable.
  • A participant questions how to handle potential changes in temperature during the process, referencing the relationship delta s equals q/t for reversible processes.
  • Another participant reminds the group to consider the ideal gas law, suggesting it may simplify the analysis of the problem.
Participants do not appear to reach a consensus on how to approach the problem, as there are differing views on handling irreversible processes and changes in temperature. Multiple competing perspectives remain regarding the application of thermodynamic principles.
There is uncertainty regarding the applicability of standard thermodynamic equations to irreversible processes and how to effectively calculate changes in entropy and Gibbs free energy without resolving the underlying complexities of the system.
Students and enthusiasts of thermodynamics, particularly those interested in the behavior of gases and the application of thermodynamic principles to irreversible processes.
nkk2008
Ok, so here is my problem:
Suppose 2.00 mole of an ideal, monatomic gas is initially at a pressure of 3.00 atm and a temperature of 350K. It is expanded irreversibly and adiabatically against a constant external pressure of 1.00 atm until the volume has doubled.
A) Calculate delta S for the system, the surroundings, and the universe (i.e. total).
Hint: To find delta S of system, consider breaking up the expansion into two steps. Based on the properties of and relationships for delta S, think of why you can and must do this.
B)If the absolute entropy per mole of the gas before the expansion is 158.2 J/K mol, calculate delta Gibbs free energy for the process.
Hint: You must use the generally defined relationship for delta G.
We do not want the answers, but my friend and I have no idea where to start. IF you could at least tell us what the hint in part A means we could go from there.
Thank you.
The standard thermo equations apply only to systems in equilibrium, so they're of little use against irreversible processes. A neat trick is to split an irreversible process into multiple reversible parts. (For example, we might extract work via a piston, but then dump that energy right back in as heat.) The starting and ending states are the same, but the requirement of reversibility is now fulfilled and the equations are now tractable. Is this enough to get you started?
But how do I deal with any changes in temperature? Are there any? In class we learned that delta s equaled q/t, where q was equal to delta h for reversible processes
Remember that it's an ideal gas, and apply the ideal gas law if it simplifies things.
10K
