Effect of Light Intensity on Photoelectron Kinetic Energy and Emission Rate
  • Thread starter Thread starter stickplot
    Photoelectrons
The discussion revolves around the effect of light intensity on the kinetic energy of photoelectrons and their emission rate from a metal surface. The original poster poses a question about how doubling the intensity of light affects the maximum kinetic energy (Kmax) and the rate of photoelectron emission (N), while assuming 100% efficiency.
  • Participants explore the relationship between light intensity, frequency, and wavelength, questioning how changes in intensity might affect the number of emitted photons and the maximum kinetic energy of photoelectrons.
Some participants suggest that if the intensity of light doubles, the number of photons would also double, while Kmax would remain unchanged. There is ongoing exploration of these ideas, but no explicit consensus has been reached.
Participants note that light intensity is related to the number of photons and energy flux, raising questions about the definitions and relationships between intensity, frequency, and wavelength in the context of the photoelectric effect.
stickplot
A metal gives off photoelectrons with maximum kinetic energy Kmax at the rate of N per second when a beam of light of wavelength λ shines on it. How will Kmax and N change if the intensity (brightness) of light is doubled? Assume 100% efficiency.
hc/wavelength=? then. P/?=
h=planks constant
c= speed of light
p=power
kinetic energy will remain the same
n will double
Im not sure how to do this problem
if the brightness doubles, will the frequency double? or the wavelength?
and I am not sure how that would affect n per second
so what I am basically asking is. Is the intensity of light related to the frequency, and if so, in what way?
h=planks constant
c= speed of light
p=power
n will double
Light intensity is a measure of the [time-averaged] energy flux and has S.I. units of W.m-2. In other words, light intensity is a measure of the average amount of energy passing through the unit surface. In terms of photons, the intensity of light is directly proportional to the number of photons passing through the unit area per unit time.
Perhaps this will help: http://www.Newton.dep.anl.gov/askasci/phy05/phy05113.htm
ok. so does that mean that the photons would double in number since the brightness doubles, and kmax would remain the same.
is this right?
is this right?
Sounds about right to me :approve:
alright thanks :)
  • · Replies 35 ·
17K
9K
