Particle is moved - Work-kinetic energy
  • Thread starter Thread starter Fendergutt
    Energy Particle
The discussion focuses on calculating work done by a force on a particle, determining its final velocity, and evaluating the rate of energy transfer. The force applied is F = <2x^2, 0>, and the particle's mass is 2.00 kg. The work done by the force is calculated as W = 32 N-m, leading to a final velocity of approximately 6.9 m/s. The power at the start is 0 W, while the power at the final position is approximately 455 W, indicating a significant increase in energy transfer.
  • Understanding of Newton's laws of motion
  • Familiarity with the work-energy theorem
  • Knowledge of vector mathematics
  • Basic principles of power calculation in physics
  • Study the work-energy theorem in detail
  • Learn about vector components and their applications in physics
  • Explore power calculations in dynamic systems
  • Investigate the implications of energy transfer in mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of work and energy concepts in action.
Fendergutt
A 2.00 kg particle is moved from the coordinates (1.00, 3.00) m to (5.00, 7.00) m.
(q1) How much work is done by the force F = <2x^2, 0> on the particle? (Assume that the force is in Newton when x is in metres.)
(q2) If the particle has start velocity v_i = <0, 4.00 m/s>, what is the final velocity v_f? (Hint: the "work - kinetic energy"-theorem can be useful.)
(q3) Determine the rate of energy transfer (i.e. the effect P) from the force to the particle, at start and final position. (Answers: P_i = 0 W, P_f = 455 W.)
(q1) I made a position vector AB = <4, 4>. It takes the particle from (1, 3) to (5, 7). We consider the positional vector's component that is parallell with F.
--> x = 4 m --> W_F = 2 * 4^2 = 32, that is 32 N.
(q2) Start velocity v_i = <0, 4.00 m/s> is constant in y-direction since the only working force on the particle is F, but this force is perpendicular on v_i, and will therefore not alter it.
"Work - kinetic energy"-theorem:
W_total = (delta)K = (1/2)*m(v_F)^2
<--> v_F = sqrt( (2(W_F)) / m ) = sqrt( (2*32 N) / (2 kg) ) = 4sqrt(2) m/s
--> v_f = <v_F, v_i>
--> ||v_f|| = sqrt((v_F)^2 + (v_i)^2) = sqrt( (4sqrt2 m/s)^2 + (4.00 m/s)^2 ) = 4sqrt3 m/s =~ 6.9 m/s
that is in the direction of the vector AB, 45 degrees anticlockwise with the x-axis.
(q3) Effect from force on particle:
at start: P = dW/dt = F[/*v_i = F * v_i * cos(alpha) = 2*0^2*cos(pi/2) = 0.
ie 0 W
at end: P = dW/dt = F*v_f = F*v_f*cos(theta) = 2* 4^2 * 4sqrt3 * cos(pi/4) W = 64sqrt6 W =~ 157 W.
answer: at start: 0 W, at end: 455 W
I must have done something wrong here. I believe the error follows from my try at (q2). Please comment or help me with getting this problem right. Thanks a lot for your time.
Welcome to PF.
For 1) I would suggest that your answer isn't in the right units for work. You got 32 N and W is in N-m.
Specifically W = ∫ F(x)⋅dx
Since your Force has no component in Y then you would use x2 as your F(x). You would evaluate that over the range of x from 1 to 5. This method will yield work as N-m.
Using this result - the work supplied - and starting with an initial kinetic energy given by ½mv² after adding the work to that you can determine the velocity at (5,7)
  • · Replies 38 ·
