Solve Dynamics Problem: Calculate x- and y-components of Position & Velocity
  • Thread starter Thread starter hkapoor
    Dynamics
The problem involves calculating the x- and y-components of position and velocity for an airplane being tracked by two radar stations. The context is within the subject area of dynamics, specifically relating to motion and angular measurements.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the use of trigonometric relationships to determine the coordinates of the airplane based on the angles and distance between the radar stations. There is a focus on setting up equations to find the unknown coordinates.
The discussion is ongoing, with some participants suggesting the use of geometric representations to aid in understanding the problem. There is acknowledgment of missing information regarding the coordinates of point M, which is prompting further exploration of the setup.
Participants note the absence of specific coordinates for point M and emphasize the need to derive these from the provided angles and distance between the radar stations.
hkapoor
Any help would be appreciated. Thanks.
An airplane is being tracked by two radar station which are a distance "s" apart from each other. Each radar station can measure the angle between the horizontal and the line from the station to the airplane and can measure the rate of change of the angle.
Your data are :
Distance s = 1600 m
Angles :
α = 40 o
β = 60 o
Angular velocities :
alpha= 1.7 o/sec
beta= 2.7 o/sec
Enter the x- and y-component of the position :
Enter the x- and y-component of the velocity :
Welcome to PF :smile:
For starters, try drawing a right triangle using the angle α and the point M. Then use what you know about trig to relate α and the x,y coordinates of M.
I don't have the x,y coordinates of M. just the distance from point 1 to 2.
For now, the x,y coordinates of M are just "x" and "y". The idea is to set up some equations from which you can figure out their values.
  • · Replies 23 ·
  • · Replies 17 ·
