Magnetic Field of a Coil w/ N Spire: Determining Off-Axis Fields
The discussion centers on determining the magnetic field of a coil with N spires at a point P that is not located on the central axis of the coil. Participants explore methods for calculating off-axis magnetic fields, referencing advanced theoretical approaches.
  • Technical explanation, Exploratory
  • One participant inquires about the possibility of calculating the magnetic field at a point off the central axis of a coil.
  • Another participant mentions that this topic is covered in advanced textbooks and suggests using Legendre polynomials for expansion of the magnetic scalar potential.
  • There is a reference to elliptic integrals as another method for determining the magnetic field off-axis.
  • A request for recommendations on advanced textbooks is made, specifically seeking sources that cover the topic.
  • A specific textbook, "Classical Electromagnetism" by Franklin, is cited as containing relevant information in a particular section.
Participants generally agree that advanced methods exist for calculating off-axis magnetic fields, but there is no consensus on the best approach or specific resources beyond the mentioned textbook.
The discussion does not resolve the complexities involved in calculating off-axis magnetic fields, nor does it clarify the limitations of the suggested methods or the assumptions required for their application.
cataldo
Hi everybody. I have a question on a magnetic field of a coil with N spire . I know the magnetic fields on point P that it has a about distance form coil center and staies on the central axis of the coil. Is possibile to determinate the magnetic filed of the coil on point P that does not stay on central axis of the coil? For example the point P staies on axis that has a distance above o below from central axis of the coil.
Sorry if i do not write a perfect english...
Best regards
That is done in advanced textbooks.
The simplest is to expand the magnetic scalar potential in Legendre polynomials.
Another method leads to elliptic integrals.
Hi clem. tanks for your replay..
Can you suggest some advanced textbook where i found this topic?
"Classical Electromagnetism" by Franklin does this in Sec. 7.10.1 using Legendre polynomials.
  • · Replies 43 ·
  • · Replies 16 ·
  • · Replies 27 ·
