Mechanics of Materials: Simple moment question?
The discussion focuses on calculating the compressive stress on part C of wood shores supporting a retaining wall, which is subjected to a triangularly distributed soil pressure resulting in a resultant force of 190 kN over a 3m length. The shores are positioned at a 30-degree angle and have a cross-section of 150mm x 150mm. Participants emphasize the importance of breaking down forces into components and applying equilibrium equations to analyze the system effectively.
  • Understanding of normal stress and strain concepts
  • Familiarity with equilibrium equations in statics
  • Ability to draw and interpret free-body diagrams
  • Knowledge of basic mechanics of materials principles
  • Study the application of equilibrium equations in structural analysis
  • Learn how to draw and analyze free-body diagrams for complex structures
  • Explore the concept of compressive stress in materials
  • Review triangular load distributions and their effects on structural elements
Students and professionals in civil engineering, structural engineering, and mechanics of materials who are dealing with load analysis and stress calculations in structural systems.
Seraph042
A long retaining wall is braced by wood shores set at an angle of 30 degrees and supported by concrete thrust blocks. The shores are evenly spaced, 3m apart.
For analysis purposes, the wall and shored are idealized. Note that the base of the wall and both ends of the shored are assumed to be pinned. The pressure of the soil against the wall is assumed to be triangularly distributed, and the resultant force action on a 3m length of the wall is 190 kN.
If each shore has a 150mm x 150mm square cross-section, what is the compressive stress on part C in the shores?
This is in part 1.2 of my book, labeled 'Normal Stress and Strain', and they give equations of moments as:
Mx = P[tex]\overline{y}[/tex]
My = -P[tex]\overline{x}[/tex]
http://img101.imageshack.us/img101/9463/128mn6.th.png
I honestly have no idea where to begin, the book has been no help with these problems, as there is almost no information or examples on how to solve this type of problem.
Please help!
Seraph042: You know the direction of the force in member BC, right? Can you break that force into horizontal and vertical components?
Secondly, have you heard of equilibrium, and the three equilibrium equations in statics? Draw a free-body diagram of member AB, and use the equilibrium equations to solve for the reaction forces at points A and B.
  • · Replies 16 ·
  • · Replies 17 ·
9K
  • · Replies 17 ·
11K
