Intersection Form in 4-D. Followup.
  • Context: Graduate
  • Thread starter Thread starter WWGD
    Form Intersection
The discussion revolves around the intersection form in 4-dimensional orientable manifolds, particularly focusing on the properties of cohomology groups and the representation of bilinear maps. Participants explore the nature of the intersection form, the relationship between cup and cap products, and the implications of torsion in homology and cohomology.
  • Some participants express uncertainty about whether H^2(M;Z) is a vector space or a ring, questioning how to represent the intersection form as a quadratic form if it is not a ring.
  • There is a discussion on the restriction of the cup product pairing to the non-torsion part of the cohomology groups, with some participants noting that cohomology is a free abelian group and thus has a basis.
  • One participant suggests that Poincare duality over Z does not apply unless the manifold is orientable, leading to the conclusion that cup products with torsion classes yield zero.
  • Another participant seeks clarification on the concept of torsion cycles/cocycles and their relation to simple-connectedness, expressing confusion about the implications of Hurewicz's theorem.
  • There is a discussion about the algebraic structure of abelian groups, with some participants explaining that torsion refers to elements for which a finite multiple equals zero.
  • A participant challenges the assertion that simply connected manifolds cannot have torsion Z-cohomology in dimension 2, requesting a proof for this claim.
Participants express various viewpoints on the nature of H^2(M;Z) and the implications of torsion in homology and cohomology, indicating that multiple competing views remain. The discussion does not reach a consensus on several points, particularly regarding the relationship between torsion and simple-connectedness.
The discussion includes limitations related to the definitions of torsion and the assumptions made about the properties of cohomology groups. Some participants note the dependence on the choice of coefficients and the implications of orientability.
This discussion may be useful for those studying algebraic topology, particularly in understanding the properties of cohomology and the implications of torsion in various contexts.
WWGD
I hope this is not too dumb. I am kind of unclear on some issues:
i) I understand that every bilinear map over a fin. dim. V space /F has
a matrix representation (depending on the choice of basis ). Still,
the intersection form ( in an orientable 4-mfld M.) is a map:
f: H^2(M;Z)xH^2(M;Z) -->Z
with:
f(a,b) =(a\/b)[M]
where M is a fundamental (orientation ) class , i.e., M is a generator of
H^4(M;Z) ~ Z (since M is assumed orientable).
Now:
It is not clear that H^2(M;Z) is a vector space. It may be a ring, and
therefore may not have a basis ( I think we consider rings as modules over
themselves, and see if they are free or not. ). If H^2(M;Z) is not a ring:
How do we represent the form above as a quadratic form?.
ii) If we do have a representation: how do we use the relation between
cap and cup (together with Poincare duality), to show that the cupping
of H_2(M;Z)\/H_2(M;Z) is equivalent to the intersection number
a.b , where a,b are the Poincare duals to the H^2(M;Z)'s ( I am working
under the result that every class H^2(M;Z) can be represented by an
embedded submanifold, and that the submanifolds can be disturbed if they
do not intersect transversally )
Thanks For any Help.
with:
f(a,b) =(a\/b)[M]
Now:
The cup product pairing over Z is usually restricted to the non-torsion part of the cohomology groups. In this case, the cohomology is a free abelian group and so has a basis.
However since the cohomology is Abelian you can still define the pairing in terms of a set of generators of the group.
I assume that you mean only to use the non-torsion part because in part 2 of your question you use Poincare duality. Poincare duality over Z doesn't work unless the manifold is orientable over Z in which case cup product with torsion classes in the bilinear pairing will always give zero and is thus uninteresting.
For part 2 you need to show that the Poincare dual to an orientable embedded sub-manifold
of an orientable manifold is the Thom class of its normal bundle.You then show that the cup product of two Thom classes is the Poincare dual to the intersection manifold where you intersect after choosing representative manifolds of the two homology classes that intersect transversally.
Thanks, Wofsy, that was helpful. A followup, please:
I have been trying to follow your advice. Something I am unclear on still, tho,
is on what a torsion cycle/cocycle is. Since I have not done heavy homology/
cohomology in a while, I am kind of rusty; all I can remember is that in some
cases, like when constructing a K(M,G) (an Eilenberg-McLane space) , if we wanted
G=Z/pZ , we would introduce torsion by introducing a relation to Z , like declaring
that twisting a cycle p times would give us a zero.
Something else I am a bit confused in what I have been looking for is the relation
between simple-connectedness and torsion : I see that if H_1(X,Z) is zero, then
H_2(X,Z) has no torsion, but I am not too clear (not being clear on what a torsion
(co)cycle is) on what is going on here. I wonder if we are using Hurewicz (since
simple-connectedness is assumed as including path-connectedness. )
Hope the wheels will be better-oiled soon.
I am back: just wanted to clarify that the algebraic torsion seems clear; depending
on the generators of the (co)homology. It is the geometric perspective that is not
clear.
Thanks Again.
Sorry, I hit the 'Reply' button involuntarily: if you could please give me a source, ref.
for the concept.
All homology and cohomology groups regardless of coefficients are abelian groups. Abelian groups have a simple structure. They are the direct product of a free Abelian group (direct product of copies of Z) and a torsion part which is a direct product of finite cyclic groups.
Torsion just means that some integer multiple of the group element is zero. So in Z/2 twice any element is zero. In Z/3, three times any element is zero.
The structure of Abelian groups has nothing to do with cohomology per se. It is a purely algebraic fact. The most elegant and wonderful way to learn this is to learn the structure theorem for modules of finite type over a principal ideal domain. Finitely generated Abelian groups are modules over Z.
So a typical Abelian group will look like ZxZ...xZ xZ/n1x...xZ/n2. For instance ZxZ/2xZ/3.
Or Z/6xZ/10xZ/2000.
If a finite dimensional manifold is orientable over Z then its top dimension homology group is isomorphic to Z. Any top dimensional coholomology class is a Z-linear map of the top homology group into Z. So if this cohomology class is a torsion class it must be zero. For instance suppose this cohomology class is 2 torsion and call it S and call the generator of the top homology class x.
Then 0 = (2S)(x)
= 2S(x) (by Z linearity)
But S(x) is an integer and the only integer whose double is zero is zero itself. Thus S is zero.
I do not know why a simply connected manifold can not have torsion Z-cohomology in dimension 2.
In fact I don't believe it. Can you give me a proof?
Regards
wofsy
clear.
Thanks Again.
In homology, torsion arises when finite multiples of cycles are boundaries.
In manifolds this can happen in any dimension.
In dimension one the simplest example is the projection of half of a great circle onto the projective plane via the antipodal mapping ( the 2 fold cover of P2 by S2).
This semi-great circle projects to a cycle in P2 because its end points are antipodal and are thus identified in P2. The entire great circle projects to twice this circle in P2. But the entire great circle is a boundary as is easily seen intuitively. Thus its projection, which is twice the original cycle in P2, is also a boundary.
Further, P2 is a non-orientable manifold. This means that any attempt to form a Z-cycle in dimension 2 fails. Its top homology over Z is zero. It is instructive to figure this out with diagrams. It all becomes clear.
wofsy
Then 0 = (2S)(x)
Wofsy:
I was going over this post again, and I was a bit confused about something: I understand
that, by duality of cohomology w.resp. to homology, every cohomology class can be
represented by a Z-linear map from a cycle into Z. Still: what do you mean by a Z-linear
map into Z in cohomology being torsion. Doesn't this imply (C is a cycle class rep.):
S: [M]-->Z ; M is the fundamental class.
S(C)=/0 , but 2S(C)=0
doesn't this imply that there are no torsion elements in here, i.e., the only way
2S(C)=0 , is if S(C)==0 . But then S must be the zero map.
I hope this makes sense. I am reviewing my Hatcher, just in case.
Regards
wofsy[/QUOTE]
Then 0 = (2S)(x)
Wofsy:
Regards
wofsy
[/QUOTE]
You are right - a torsion class in the top dimension must be zero.
My point was that when taking cup products of two cohomology classes, one of them may be a torsion class in a lower dimension. When cupped up to the top dimension you still have a torsion class so it in fact must be zero.
Just to say thanks again, Wofsy. Unfortunately, as you see , at this point, my
algebraic topology is still relatively weak, so I am not able to answer your questions
at this point. I am stronger at this point in the point-set , and analysis-side; hopefully
if you need help in these, I may be able to answer a question.
It was a pleasure to help you. Anytime.
Regards
wofsy[/QUOTE]
I think this is false: Take an Eilenberg-Mclane K(G,2), with G a torsion group.
Then ,Pi_1 =0 , and by Hurewicz (Hip, Hip, Hurewicz! :) ) Pi_2=G =H_2 has torsion.
I meant to say that I think my claim was false.
Regards
wofsy
Then ,Pi_1 =0 , and by Hurewicz (Hip, Hip, Hurewicz! :) ) Pi_2=G =H_2 has torsion.[/QUOTE]
is there one of these that is a manifold?
By the universal coefficient theorem in cohomology:
[tex]0\to\text{Ext}(H_1(M),\mathbb{Z})\to H^2(M;\mathbb{Z})\to \text{Hom}(H_2(M),\mathbb{Z})\to 0[/tex]
is exact. Furthermore if [tex]H_2(M)[/tex] is finitely generated, then [tex]\text{Hom}(H_2(M),\mathbb{Z})[/tex] is isomorphic to the free part of [tex]H_2(M)[/tex]. Thus, in the case [tex]H_1(M)=0[/tex], [tex]H^2(M)[/tex] is torsion free.
Also, if M is a closed connected orientable 3-manifold, then the torsion subgroup of [tex]H_{2}(M)[/tex] is trivial (see Hatcher p. 238).
very cool. thanks
Wofsy: I just thought of another argument for the quotient of the Abelian group A
by torsion has a basis: A torsion-free module over a PID is free .
In our case, Z is the PID, ( since Z is a Euclidean ring, it is a PID) .
that is correct. There is a general theorem for modules of finite type over a PID which is well worth learning.
Hi again:
of an orientable manifold is the Thom class of its normal bundle.You then show that the cup product of two Thom classes is the Poincare dual to the intersection manifold where you intersect after choosing representative manifolds of the two homology classes that intersect transversally.[/QUOTE]
I have followed up on this. Now I am trying to show that if M is compact and boundaryless, then the intersection form is unimodular ( i.e., has determinant +/- 1
which implies that it is invertible over Z ). The results I am trying (without much
success ) are:
i)
If g is an element in a free Abelian group g , and Q is a quadratic form over
(i.e., defined on) G , then the map:
L: G-->G* , with G* the dual to G ( i.e., all linear maps from G into Z)
with L: g--> Q(g,s) ( s in G)
is an isomorphism iff Q is unimodular . "
ii) Just Poincare duality, since M is closed.
So I need to take an element x in H^2(X;Z) ( maybe working in H_2(X;Z) may
make more sense) and I am trying to show that the map : x--> Q( x,y) , is an
isomorphism. I am pretty sure Poincare duality would help here, but I am not too clear
on how.
Thanks for any ideas.
WWGD said:
Hi again:
success ) are:
i)
on how.
Hi WW I have tried to do this proof and have failed so far. But you can see how Poincare duality is involved. If the dual map is an isomorphism from the second homology to the second cohomology then it is easy to see in simple cases that the intersection product must be unimodular. Take the case where a Z -basis of the homology lattice is also a set of eigen-vectors of the intersection matrix. Then all of the eigen-values must be non-zero integers. If one of these eigen-values has absolute value greater than 1 then the linear map that maps its eigen vector to 1 and all others to zero can not be represented with the quadratic form.
Similarly if you had a quadratic form whose matrix interchanged basis vectors with a scale factor like (1,0) -> (0,2) (0,1) - > (2,0) then the linear map that sends (1,0) to 1 and (0,1) to zero can not be represented with the quadratic form.
But in general I'm not sure. Let's think about it some more.
Let Q be the matrix representation for the bilinear intersection form with respect to a Z basis , V1...Vn, for H_2(M;Z).
The intersection pairing can be expressed as x.Q(w) where . is the dot product with w and x written in Vi co-ordinates.
The dual homomorphism Li, defined by Li(Vi) = 1 , Li(Vj) = 0, is thus x.Q(Q inverse (Vi)).
Poincare duality says that every homomorphism of H_2(M;Z) into Z can be represented as the product <w,x> with some fixed w in H_2(M;Z). This implies that Q inverse (Vi) is in H_2(M;Z). Otherwise put, Q inverse is an integer matrix. It thus has integer determinant. But its determinant is the reciprocal of the determinant of Q which is also an integer. The only way this can happen is if both determinants are +- 1.
  • · Replies 16 ·
  • · Replies 19 ·
