What is the value of its x-component?
  • Thread starter Thread starter bpatel4116
    Value
The discussion focuses on calculating the x-component of a velocity vector that is 55 degrees below the positive x-axis with a known y-component of -13 m/s. To find the x-component, one must apply trigonometric functions, specifically using the cosine function. The x-component can be calculated as x = y / tan(θ), where θ is the angle of the vector. In this case, the x-component is approximately 7.5 m/s.
  • Understanding of vector components
  • Basic trigonometry, including sine and cosine functions
  • Knowledge of how to draw and interpret vector diagrams
  • Familiarity with the concept of angles in standard position
  • Study the use of trigonometric functions in vector analysis
  • Learn about vector addition and subtraction
  • Explore the application of vectors in physics problems
  • Review the concepts of angle measurement and conversion between degrees and radians
Students in physics, engineers working with vector mechanics, and anyone needing to solve problems involving velocity vectors and their components.
bpatel4116
A velocity vector 55 degrees below the positive x-axis has a y-component of -13 m/s.
Ive tried many different ways for this problem but i keep getting it wrong! help!
Welcome to PF.
If your vector is pointing 55° down then draw the diagram.
You have a triangle - you have the angle - they tell you a side - then figure out the length of the hippopotamus.
  • · Replies 21 ·
