More linear algebra - Perpindicular Line spanned by a vector
The discussion revolves around a linear algebra problem concerning the line spanned by the vector [1, 2, 3] in \(\mathbb{R}^3\) and the task of finding a basis for the perpendicular subspace associated with this line.
  • Participants explore the meaning of the phrase "line spanned by [1, 2, 3] in \(\mathbb{R}^3\)" and discuss the geometric implications of spans and bases. There are attempts to formulate equations involving dot products to identify vectors that are perpendicular to the given vector.
The discussion is ongoing, with participants questioning each other's understanding of concepts and terminology. Some guidance has been offered regarding the use of dot products to find perpendicular vectors, but there is no explicit consensus on the next steps or the correct formulation of the problem.
Participants express varying levels of confidence in their understanding of spans and bases, indicating that some foundational concepts may still be unclear. There is a mix of mathematical notation and informal language, which may contribute to confusion about the problem setup.
succubus
I'm back, I'm just brushing up on some linear algebra for my test tomorrow and am doing some recommended questions. I have a bit of confusion on some of them, and some of them I just want to make sure my thinking is correct.
So on to the problem...
Consider the line spanned by
in [tex]\Re^{3}[/tex] Find a basis of [tex]\bot[/tex]L
So the basis would be the set of all independent column? vectors... Since it's [tex]\Re^{3}[/tex] I would assume that it is at least n x 3? So would I find a vector that when dotted against this would equal 0? :/
Do you know what the phrase "line spanned by [1 2 3]^T in R^3" means?
No, I don't think so. I'm not sure what you mean by independent column vectors. I think you might be getting ahead of yourself by thinking in terms of a matrix before you fully comprehend the geometry here.
... Since it's [itex]\Re^{3}[/itex]
What is? Again, I think you're getting ahead of yourself by thinking about matrices. At least that's what it seems like.
That's an excellent idea! The perpendicular subspace consists of vectors that are perpendicular to the line, so the dot product of anyone of them with the vector that generates the line should be zero.
Write an equation that expresses this idea and you'll be on your way to solving this problem.
Well, I've come up with [tex]\overline{x_{1}}[/tex] + 2[tex]\overline{v_{2}}[/tex] + 3[tex]\overline{v_{3}}[/tex] = 0
And since the first column vector has a 1 coefficient (or can be made that way in any other case), then I solve for
[tex]\overline{v_{1}}[/tex] = -2[tex]\overline{v_{2}}[/tex] - 3[tex]\overline{v_{3}}[/tex]
Then where do I go?
"Do you know what the phrase "line spanned by [1 2 3]^T in R^3" means?"
Could you explain a little in more detail. I somewhat understand the concept of a span and basis. We just started getting into these concepts in class. I'm shaky in my confidence. The concept is testing me spatially :(
Nope, that's not it at all. You shouldn't have an equation with vectors in it after you have taken a dot product. Also, you're mixing up x's and v's, which makes things only slightly worse.
Then where do I go?
When the text talks about a space spanned by a collection of vectors, it means the set of all linear combinations of those vectors. For example, the span of {v1, v2, v3} is the set of all possible sums c1 * v1 + c2 * v2 + c3 * v3, where the c's are scalars and the v's are the vectors. If we're talking about the space spanned by one vector, the set of all linear combinations of one thing is c1 * v1. In other words, scalar multiples of the vector v1. This is a line through the origin. The line spanned by [1 2 3] is the line through the origin that goes through (1, 2, 3), and (2, 4, 6), and (-3, -6, -9), and (sqrt(7), 2sqrt(7), 3sqrt(7), and ...
Back to the problem at hand. You have a vector, [1 2 3]. You want to find the subspace of R^3 consisting of vectors that are perpendicular (hint: dot product) to [1 2 3]. What does your arbitrary, garden-variety vector in R^3 look like?
