Comparing Topologies: Rl and Rk vs. Standard Topology
  • Context: Graduate
  • Thread starter Thread starter tomboi03
The discussion focuses on comparing the lower limit topology Rl and the topology Rk, defined as the set of all numbers of the form 1/n for positive integers n, against the standard topology T. It is established that Rl is strictly finer than T, as every basis element [x,b) for Rl contains x and lies within (a,b), while no open interval (a,b) can be found that contains x and lies in [x,d). Similarly, Rk is shown to contain points from T but lacks open intervals that satisfy the conditions of T. The key takeaway is that not all topologies are comparable, and to prove comparability, one must demonstrate the existence of open sets in one topology that are not present in the other.
  • Understanding of topology concepts, specifically lower limit topology and standard topology.
  • Familiarity with basis elements in topological spaces.
  • Knowledge of open sets and their properties in different topologies.
  • Experience with mathematical proofs and comparisons of topological structures.
  • Study the properties of lower limit topology Rl in detail.
  • Explore the characteristics of Rk and its implications in topology.
  • Learn about the concept of basis elements in topological spaces.
  • Investigate methods for proving comparability between different topologies.
Mathematicians, topology students, and educators seeking to deepen their understanding of topological comparisons and properties.
tomboi03
The question is
Show that the topologies of Rl (which is the lower limit topology) and then... RK (which is the set of all numbers of the form 1/n, for n E [tex]Z[/tex]+ meaning that they are all 1/n for all the positive integers)
So i can compare this to the standard topology which is...
Given a basis element (a,b) for the standard topology (i will call this T) and a point x of (a,b), the basis element [x,b)for Rl contains x and lies in (a,b). ON the other hand, given the basis element [x,b) for Rl there is no open interval (a,b) that contians x and lies in [x,d). Thus Rl is strictly finer than T.
same applies to Rk.
Given a basis element (a,b) for the standard topology (i will call this T) and a point x of (a,b), the basis element for Rk contains x. ON the other hand, given the basis element B=(-1,2) - K for Rk and the point 0 of B, There is no open interval that contains 0 and lies in B.
I don't know how i can compare the two together... i might be like blind... and that i might be right under my nose... but still.. I'm struggling.
Not all topologies are comparable. If you want to prove that one is more comparable than the other, you prove that all open sets in one are open sets in the other. To prove that two topologies aren't comparable, find an open set in one that isn't open in the other, then find one that is open in the other that isn't open in the first one.
  • · Replies 17 ·
  • · Replies 58 ·
  • · Replies 31 ·
