Double Integral over B: Evaluate x^2y^3
  • Thread starter Thread starter cse63146
    Integral
The problem involves evaluating a double integral of the function x^2y^3 over a closed region B, defined by the curves y = x^2 and y = x. Participants are exploring the setup and interpretation of the integral within the specified bounds.
  • Participants discuss the setup of the integral, questioning whether the parameters have been correctly defined. There is a focus on comparing the values of y and sqrt(y) within the bounds of integration. Some participants express confusion regarding the implications of taking absolute values of the results.
The discussion is active, with participants clarifying their understanding of the relationships between the variables involved. Some guidance has been provided regarding the comparison of y and sqrt(y), and there is an acknowledgment of the potential need to adjust the integral setup if the bounds change.
Participants are considering the implications of changing the bounds of y from [0, 1] to [0, 2], which introduces additional complexity to the integral setup. There is an ongoing examination of assumptions related to the behavior of the functions involved.
cse63146
Evaluate the following double integral over the closed region B:
[tex]\int\int_B x^2 y^3 dx dy[/tex] where B is the region bounded by y = x^2 and y = x
I think I set up the paramaters wrong:
[tex]\int^{1}_{0}\int^{y}_{\sqrt{y}} x^2 y^3 dx dy[/tex]
If y is in [0,1], as it looks like you've figured out for your integral, which is larger y or sqrt(y)? Is that what's confusing you?
y>sqrt(y)
The answer is 1/77, but I get -1/77, but taking it's absolute value should take care of that.
cse63146 said:
y>sqrt(y)
What's sqrt(1/4)?
cse63146 said:
y>sqrt(y)
Can you explain why "taking its absolute value" is justified?
Once again, which is larger, y or [itex]\sqrt{y}[/itex] for y between 0 and 1?
Which is larger 1/4 or [itex]\sqrt{1/4}[/itex]?
I get it. Because y goes from 0 - 1, sqrt(y)>y in this case.
but what if y went from 0 - 2, then would it be this:
[tex]\int^{1}_{0}\int^{\sqrt{y}} }_{y} x^2 y^3 dx dy + \int^{2}_{1}\int^{y}_{\sqrt{y}} x^2 y^3 dx dy[/tex]
Yes.
Thank you all for your help.
