Defining implicit function given a parametric function
The discussion focuses on defining a continuous implicit function g: R3 -> R from a given continuous parametric function f: R2 -> R3 that describes a 2D surface in 3D space. The key insight is that g can be defined as the distance from a point in R3 to the surface defined by f, utilizing the infimum function to establish the relationship. The implicit function g is non-negative everywhere, equating to zero on the surface. This approach emphasizes the continuity and increasing nature of g outside the surface.
  • Understanding of continuous functions and their properties
  • Familiarity with parametric equations in three-dimensional space
  • Knowledge of implicit functions and their definitions
  • Concept of infimum in mathematical analysis
  • Research the properties of continuous functions in multivariable calculus
  • Study the concept of distance functions in geometry
  • Learn about implicit function theorems and their applications
  • Explore the use of infimum in defining distance metrics
Mathematics students, particularly those studying multivariable calculus, geometry, and analysis, as well as educators looking for insights into implicit function definitions and parametric surfaces.
mathnewbie123
Given a continuous parametric function f : R2 -> R3 specifying a 2D
surface in 3D space, define a continuous implicit function g : R3 -> R
corresponding to the same surface.
You’ll likely want to use the infimum function.
You can ignore the inside/outside convention: g can be everywhere
nonnegative.
My thought on this is that... Since g is an implicit function and is non negative everywhere else.. Then if a point lies on the surface described by g, g(x,y,z) = 0 at that point. Since g is zero on the surface and continuous and increasing everywhere else, it must include an infimum of some sort and a modified function of f, where f(s,t) = (x,y,z).. And I'm stuck from then on..
Someone help please? Any help is appreciated..
I think they are trying to get you to think of defining g as the distance from a point to the surface. Can you define this distance in terms of an infimum?
  • · Replies 16 ·
  • · Replies 27 ·
