Velocity and distance traveled of a particle
The problem involves a particle moving along the x-axis, described by a quadratic position function. Given the acceleration at a specific time and the points at which the particle passes through the origin, the original poster seeks to determine the velocity at a certain time and the maximum distance from the origin in the positive x-direction.
  • The original poster attempts to differentiate and integrate the position equation, while also exploring a factorization approach to find constants in the equation. Some participants suggest differentiating twice to relate the constant acceleration to the coefficients.
Participants are exploring different methods to derive the constants in the equations and are questioning how to find the necessary values to calculate velocity and distance. There is an acknowledgment of the need to determine the constant C1, but no consensus on how to proceed has been reached.
There is a mention of the particle's behavior at specific times and the implications of constant acceleration, which may influence the calculations. The original poster expresses uncertainty about the correct approach to solving the problem.
cdx
(I can't seem to get the super and subscripts to work so I apologize if this looks ugly.) The position of a particle moving along the x-axis is given at time t by: x = C0 + C1t + C2t^2. At time t = 4.0s the acceleration of the object is a = -20 m/s^2 and that the object passes through the origin x = 0 at t = -2.0s and t = 6.0s. Find the velocity of the particle at t = -2.0s and the maximum value of the distance of the particle from the origin measured in the positive x-direction.
x = (0.5)at^2 + v0t + x0
I've tried three approaches: differentiating with respect to the x equation above, integrating from the acceleration given, and setting up x = 0 = (t + 2)(t - 6) from the information given.
Differentiating and integrating lead me to the same problem.. how to find the constant C in v(t) = -20t + C.
Setting up the factor-like problem I obtain t^2 -4t - 12. Looking at this equation I'm led to believe that C2 = 1, C1 = -4, and C0 = -12 from the coefficients. Taking the derivative of this, I get v(t) = 2t - 4. Deriving again I get 2 ms^2 which is not the -20 ms^2 provided.
I'm not sure how to start solving this equation correctly. Could someone point me in the right direction? Thanks.
I am a bit too lazy to completely work your problem out but from the information given, the acceleration is constant. So you simply differentiate twice to find that [tex]2C_{2} = -20[/tex]
edit: just made it a bit prettier
Yes, C2 = -10 in my calculation as well and substituting -10 back into v(t) = 2(C2)t + C1, I get v(t) = -20t + C1. How do I find C1 so that I can substitute -2 for t to solve for v(t)? Or is my answer for the velocity of the particle at time t = -2s simply v(-2) = 40 + C1 m/s? If I don't have a value for C1 then how do I find the maximum value of the distance of the particle in my original x equation?
You know where it is at t = -2 and at t = 6
It must have reversed direction in that 8 seconds. That means at T = 2 it's |V| is 0.
Since a is constant then |v| = a*t = a*4sec at the origin.
  • · Replies 20 ·
