Thread Closed
Electric Field Equation Hollow Cylinder
Share Thread Thread Tools
Feb11-09, 02:11 AM   #1
Hello,
Does anyone know of (or have a link to) an equation for the electric field at any point inside a a hollow cylinder shell of finite length?
thanks,
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Feb11-09, 07:20 AM   #2
Mentor
I've never seen one. I suspect that it's not possible to get a closed formula for all points, and that you'd have to calculate it via numerical integration or using a series approximation of some kind.
Feb11-09, 08:11 AM   #3
Recognitions:
More detail please. Is it a conducting cylinder kept at a given potential?
Are the ends open or closed?
Feb11-09, 11:18 AM   #4
Okay, let's simplify.
Suppose the cylinder is of finite length, and the point is inside the cylinder midway between the two ends. The ends are open. The charge is uniform and kept constant. The cylinder is made of conducting material.
Feb11-09, 12:28 PM   #5
Recognitions:
That is impossible. A conducting cylinder will not have a uniform charge.
Feb11-09, 01:28 PM   #6
True that.
Suppose it is made of non-conducting material such that the charge is uniformly distributed.
Feb11-09, 03:05 PM   #7
Recognitions:
That problem can be solved by taking the field or potential on the axis of a uniformly charged ring and integrating along the axis.
Feb11-09, 04:01 PM   #8
Mentor
Right, on the axis you can get an equation for the field as a function of position fairly easily. Off the axis it's much more difficult, maybe even impossible, using "common" functions.
Thread Closed
Thread Tools
Similar Threads for: Electric Field Equation Hollow Cylinder
Thread Forum Replies
two conducting hollow spheres, a point charge and electric field prob Introductory Physics Homework 5
Electric Field within Cylinder Advanced Physics Homework 2
Electric Field outside a cylinder Introductory Physics Homework 50
Finite Cylinder in an electric field Classical Physics 0
electric field of hollow ball Introductory Physics Homework 4
