Which Heat Exchanger Is Best for Rapid Cooling and Easy Maintenance?
The discussion centers on selecting an appropriate quench cooler heat exchanger for rapid cooling and easy maintenance. The user requires a system that can efficiently cool gas with inlet temperatures exceeding 250°C and condense water vapor while managing aerosols. They specifically seek a method for heat exchanger selection, as existing resources like Perry's Handbook and Wikipedia do not provide adequate guidance. Recommendations include consulting a blog on selecting TEMA-type heat exchangers and a slide presentation on shell and tube designs.
  • Understanding of heat exchanger types and their applications
  • Familiarity with quench cooling processes
  • Knowledge of TEMA standards for heat exchangers
  • Basic principles of thermodynamics and heat transfer
  • Research TEMA-type heat exchanger selection criteria
  • Explore design principles of shell and tube heat exchangers
  • Investigate methods for cleaning and maintaining heat exchangers
  • Review case studies on quench cooling applications in industrial settings
Engineers, process designers, and maintenance personnel involved in thermal management and heat exchanger selection in industrial applications.
CaptainPanic
I'm in need of a specific heat exchanger (a quench cooler). It needs to cool fast (in seconds) and it needs to cool a lot (hundreds of degrees).
The coolant is water (making steam). The other side of the heat exchanger is a gas which can be compared to an exhaust gas: there are particles (aerosols), water (which will condense) and permanent gases. Inlet temperature is well above water's boiling point, (>250 deg C) so no water is present in liquid form when it enters. Exit temperature is room temperature, so a lot will have condensed. the aerosols are expected to make everything dirty in no-time, so cleaning the heat exchanger should be easy.
I know that often quench coolers are a type of flash vessel, that doesn't do a lot of heat exchanging. A quench tower (direct contact between coolant and gas) is also no option for me. I need to recover the heat, and keep the gas pressurized.
Question: where can I find a method to select the heat exchanger? To my surprise, Perry's handbook doesn't have a "heat exchanger selection", wikipedia only describes a lot of heat exchangers...
I hope somebody can point me to a proper selection method. (Can also be a book or journal article - I have access to both in abundance). A selection method would not solve the question, but would enable me to do that myself... teaching me how to fish, rather than giving me that one fish. :-)
Of course, there's nothing wrong with answering the technical question here.
Thanks in advance.
  • · Replies 78 ·
  • · Replies 21 ·
