How High Should a Rifle Barrel Be Aimed to Hit a Target 200m Away?
To hit the center of a target 200 meters away, a rifle must be aimed at an angle of elevation of 23.6°. The bullet's initial speed is 500 m/s, and the time taken to reach the target is 0.4 seconds. The calculations involve using kinematic equations to determine the vertical displacement due to gravity, which is 3.924 m downward during the bullet's flight. This analysis confirms that the barrel must be elevated to compensate for the bullet's drop over the distance.
  • Understanding of kinematic equations in physics
  • Knowledge of projectile motion concepts
  • Familiarity with trigonometric functions, specifically sine
  • Basic knowledge of gravitational acceleration (9.81 m/s²)
  • Study the derivation of projectile motion equations
  • Learn about the effects of air resistance on bullet trajectory
  • Explore advanced ballistic calculations for varying angles and distances
  • Investigate the impact of different bullet weights and speeds on trajectory
Marksmanship enthusiasts, physics students, and anyone interested in understanding the mechanics of projectile motion and ballistics.
PinkFlamingo
A rifle is aimed horizontally at the center of a large target 200 m away. The initial speed of the bullet is 500 m/s. Where does the bullet strike the target? To hit the center of the target, the barrel must be at an angle above the line of sight. Find the angle of elecation of the barrel.
So far I know that
in the x-direction:
V0 = 500 m/s
x= 200 m
in the y-direction:
V0= 0 m/2
a = 9.81 m/s^2
and I know that they have time in common. But I don't really know where to go from here. Do we even have enough information to solve the problem?
You have 2 exercises here:
1) The rifle is aimed horizontally
You have listed the correct quantities you must use here.
2) What angle must you aim the rifle along in order to hit the center of the target?
1):
Let the origin be the muzzle of the rifle (i.e, x=0,y=0)
(This means, in particular, that the ground level has some unspecified, negative value)
a)What time does it take for the bullet to travel 200 meters horizontally?
b) After that time, how far down from y=0 has the bullet fallen?
2)
The speed of the bullet is [tex]V_{0}=500[/tex]
With a non-zero angle to the vertical, we have for the initial horizontal velocity:
[tex]V_{0,x}=500\cos\theta[/tex]
The initial vertical velocity satisfies:
[tex]V_{0,y}=500\sin\theta[/tex]
(Note that in the particular case [tex]\theta=0[/tex] we retrieve the relations for a horizontally aimed rifle)
a) What is now the time the bullet takes to traverse 200 meters in the horizontal direction?
b) Solve now for the final vertical position as a function of the initial angle.
You want to find the angle such that [tex]y_{final}=0[/tex]
Based on the information given, we can use the kinematic equations to solve for the angle of elevation of the barrel. We know that the initial velocity in the y-direction is 0 m/s, and the acceleration due to gravity is 9.81 m/s^2. We also know that the displacement in the x-direction is 200 m. Using the equation x = x0 + V0t + 1/2at^2, we can solve for the time it takes for the bullet to reach the target in the x-direction.
x = 200 m
x0 = 0 m
V0 = 500 m/s
a = 0 m/s^2
200 m = 0 + 500 m/s * t + 1/2 * 0 m/s^2 * t^2
200 m = 500 m/s * t
t = 0.4 s
Now, using the equation V = V0 + at, we can solve for the initial velocity in the y-direction.
V = 0 m/s
V0 = ?
a = 9.81 m/s^2
t = 0.4 s
0 m/s = V0 + 9.81 m/s^2 * 0.4 s
V0 = -3.924 m/s
Since we know the initial velocity in the y-direction, we can use the equation V = V0 + at to solve for the angle of elevation of the barrel.
V = 0 m/s
V0 = -3.924 m/s
a = 9.81 m/s^2
t = 0.4 s
θ = ?
0 m/s = -3.924 m/s + 9.81 m/s^2 * 0.4 s * sin(θ)
sin(θ) = 0.4
θ = sin^-1(0.4)
θ = 23.6°
Therefore, the angle of elevation of the barrel must be 23.6° in order for the bullet to hit the center of the target 200 m away with an initial speed of 500 m/s.
  • · Replies 29 ·
  • · Replies 16 ·
  • · Replies 20 ·
