Of the nobile gasses, which has the greatest propensity to ionize?
  • Thread starter Thread starter wwtog
The discussion centers on the propensity of noble gases to ionize, with a particular focus on experimental setups involving high voltage and ionization effects. The participant describes an experiment using a metallic environment with 20,000V DC voltage and explores the behavior of bubbles in this context. The conversation also touches on the properties of ionized gases when dissolved in water and their potential effects, including heating and visual phenomena. Overall, the discussion highlights the complexities of ionization and the experimental conditions that influence it.
  • Understanding of noble gases and their ionization properties
  • Knowledge of high voltage electrical systems and safety precautions
  • Familiarity with the behavior of gases in electrical fields
  • Basic principles of R-C parallel circuits and their quality factor (Q)
  • Research the ionization energies of different noble gases
  • Explore the effects of high voltage on gas behavior and ionization
  • Learn about the thermal effects of ionized gases in liquids
  • Investigate the principles of R-C circuits and their applications in electronics
Physics students, electrical engineers, and anyone interested in the behavior of gases under electrical conditions and the principles of ionization.
wwtog
(1) If I set an experiment, in a room with a metallic floor, and a metaillic ceiling. the two plates have 20,000V of dc voltage impressed across the plates. I walk in, wet footed, with the bubble master's favorite limon joy and water concentrate. I am in no danger as I am well below the breakdown field strength of air, and leave the aluminum step ladder outside.
I blow a bubble, with my metallic bubble blower, several, maybe 100. How many accellerate upward, some, many, none?
(2) Of the nobile gasses, which has the greatest propensity to ionize.
(3) what is the Q of an R-C parallel circuit. (I knoe the answer(s?) do you?)
and (4), the bonus question, if an ionized gas, dissolves into water, what becomes of the charge?, did it heat the water??
special effects, dancing bubbles, holographic disapearing talking heads. dig into your pockets and pay for someones elses imagination, (you definitely need it!) I guess this is a sophamore hang-out, I'm outta here, and taken my patent's with me! Good luck turning the same crank for the next 50 years, That is, if your job is not replaced with, a machine, or monkey, no matter, they cost about the same.
hasta la vista (baby engineers)
