Help with trigonmetric function question
  • Context: High School
  • Thread starter Thread starter maccaman
    Function
The discussion focuses on solving a trigonometric function problem related to the motion of a particle in alternating current, described by the equation v = 3 cos(t/3). The objective is to determine when the particle first reaches a displacement of -4.5 cm. By integrating the velocity equation and applying the trigonometric identity cos(t) = -cos(t + π), the solution reveals that the particle reaches the specified displacement after approximately 7.854 seconds.
  • Understanding of trigonometric functions and identities
  • Knowledge of calculus, specifically integration
  • Familiarity with particle motion equations
  • Ability to use inverse trigonometric functions
  • Study integration techniques in calculus
  • Learn about trigonometric identities and their applications
  • Explore the concepts of particle motion in physics
  • Practice solving problems involving inverse trigonometric functions
Students studying physics or mathematics, educators teaching calculus or trigonometry, and anyone interested in understanding particle motion in alternating current systems.
maccaman
This is a problem solving one, i just don't know where to start it though
The speed of a particle in an alternating current is given by the equation:
v = 3 cos t/3, where v is in cm/s and t is in seconds.
The particle's movement begins at its point of equilibrium.
How soon after the start would the particle first reach a displacement of
-4.5cm?
You are given an expression for the velocity, you need to find the displacement.
[tex]v = \frac {dx} {dt}[/tex]
so
[tex]\frac {dx} {dt} = 3 cos (\frac t 3)[/tex]
[tex]\int dx = \int 3 cos (\frac t 3) dt[/tex]
You should now be able to find an expression for the displacement as a function of time. You will need to find the time that satifies your conditions.
To solve this problem, we can use the trigonometric identity cos(t) = -cos(t + π). This identity allows us to find the time at which the particle reaches a displacement of -4.5cm by setting the equation equal to -4.5 and solving for t.
-4.5 = 3 cos t/3
cos t/3 = -1.5
Using the inverse cosine function, we can find the value of t that satisfies this equation.
t/3 = cos^-1(-1.5)
t = 3 cos^-1(-1.5)
Now, using a calculator, we can find that cos^-1(-1.5) is approximately 2.618 radians.
Therefore, t = 3(2.618) = 7.854 seconds.
Thus, the particle would first reach a displacement of -4.5cm after 7.854 seconds from the start of its movement.
  • · Replies 38 ·
