Electron orbital frequency of hydrogen atom if given orbit radius
The discussion revolves around calculating the orbital frequency of an electron in a hydrogen atom, given a specific orbit radius of 0.053 nm. Participants are exploring classical models of atomic structure and the forces acting on the electron.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss using Coulomb's law and centripetal force to derive the electron's velocity and subsequently its frequency. There are attempts to relate angular velocity and tangential velocity to the problem.
Some participants have provided corrections and suggestions regarding the application of formulas, while others express frustration over the accuracy of their calculations. There is ongoing exploration of numerical precision and significant digits in the context of the problem.
There are mentions of discrepancies in charge values and the Bohr radius, indicating potential confusion or miscommunication regarding fundamental constants. Participants also reflect on the lack of instructional support in their coursework.
Mugen112
In a classical model of the hydrogen atom, the electron moves around the proton in a circular orbit of radius 0.053 nm.
A) What is the electron's orbital frequency?
F = qE
E= kq/r^2
angular velocity = v^2/r
I'm developing a sever hate for Physics. This problem seems to be an easier problem, yet I still can't seem to get it. This is the only class that offers no support in terms of answering questions. I've read the chapters several times, yet I still have trouble seeing how the chapter and the questions after the chapter correlate. Again, this problem is an easier problem of the bunch. I don't see how the book not offering any help would be beneficial at ALL to learning the material. I learned previous chapters (kinematics/gravity/friction) all with great help from the chapter AND I understood how they formulated all their equations. I remember them and I know how to use them in a diverse aray of situations. I truly believe that they took the same questions from the previous book (Physics for Scientists and Engineers by Knight 1st ed.) and took a lot of the context out of the chapters. I know that those of you that have learned the material will probably say that it is the only way to learn this material... but I find that incredibly hard to believe. Am I the only one that thinks this or is this Physics book just put together poorly? I could write a book about how much I really hate this class... BUT ANYWAY... sorry for the vent...
So let's see here... they give the distance between the proton and electron. I have NO idea why in the hell an electron would orbit a proton (I know it does... but OK). From the fact that it is a hydrogen atom implies that there is only one proton and one electron of charge -e and e (1.16 x 10^-19 C) .
Now, because the electron orbits the proton, I suppose we would use the angular velocity formulas. The force pointing toward the center (acceleration) would be found using Coulomb's force formula?
a = v^2/r
F(or a in this case) = qE
E= Kq/r^2
so.. Kq^2/r^2 = v^2/r ?
I plug everything in and I get a number for tangential velocity to equal 1.5 x 10^-9 m/s. Then the circumference of the orbit is 2pi()(radius). I get that number... Then Plug both of those into D=RT.. solve for T, find out how many revolutions persecond for the frequency? Mastering Physics says its wrong. I give up.
It looks like you are very close:
You made an error by setting the Coulomb Force equal to the acceleration, you forgot that it should be the centripetal force which should be
[tex]K\frac{q^2}{r^2}=\frac{m v^2}{r}[/tex] which you solve as you did.
Ok, so.. I tried it again and it's still wrong.
For V, I get 1583733 m/s with the equation that you gave me.
V= sqrt (((9*10^9)((1.16*10^-19)^2)) / ((.053 * 10^-9)(9.11*10^-31)) = 1583733 m/s
Then 2pi()R = 3.33*10^-10
D = RT
3.33*10^-10 / 1583733 = 2.1 * 10^-16 s
so that's 1 revolution in 2.1 * 10^-16? So I'm guessing taking the inverse of this will give you the number of revolutions per second = 4.8 *10^15 Hz. MasteringPhysics still says this is wrong. Forgot to say thanks for the help tho.
D = RT
Well your analytic expression for v looks correct : [tex]v=\sqrt{\frac{K e^2}{r m_e}}[/tex] and your relationship between v and period is right [tex]T = 2 \pi r/v[/tex]
so the only thing possibly wrong is numerical precision, have you tried entering more significant digits? I know with the system in use at my school the computer's evaluation is based purely on percents rather than significant digits... I'm terribly sorry that I can't help any further, but everything looks right.
Unless I've forgotten something this looks right, the only problem I can see is that you have an error of
I know it doesn't matter now, because this was like 2 years ago, but e is -1.6 x 10^-19.
Bohr radius is 5.29e-11m by the way.
You are on the right track but,
Fe= Fc
Ke^2/r^2 = mv^2/r
r=Ke^2/mv^2
V^2=Ke^2/mr
∴V^2=√((9x10^9)x((1.6x10^-19)^2)/(9.11x10^-31)x(5.29x10^-11)
V= 2'186'340.09 ms-1
∴V= 2.2x10^6ms-1
∴Frequency =
2∏r/v
t= (2x∏x (5.29x10^-11))/(2.2x10^6)
∴t= 1.51x10^-16 seconds
∴f= 1/(1.51x10^-16)
∴f= 6.6x10^15 revolutions per second
There you go :)
  • · Replies 30 ·
11K
