Thread Closed
generator questions
Share Thread Thread Tools
Feb13-09, 12:22 AM   #1
generator questions
hey all :)
i'm completely new to the electrical game, but i'm very interested in this, however only as a hobby. i'm doing my best to learn as much about this as possible so please excuse my stupid questions.
ok so i'm interested in building a generator to power my home in case of outages. i could buy one, but it'd be much more fun to build one, right? ok i already have everything designed, but i will be using a dc alternator so i'm going to need to convert this to ac obviously. so i'm going to use a power inverter to accomplish this (unless there is another way?). since it's going to be hand built i would like to try to build one of these as well. i've already found a schematic for this, but the max output from this particular design is 1kw. i'm looking for an output of ~5kw, the more the merrier though. my question is, could i run these inverters in parallel to achieve this? maybe somebody can provide me with a schematic to build a larger inverter if not. like i said, i have no idea about any of this really, but i would like to do this. another question i have is that if i was to just buy a large inverter, i would obviously have to run a larger wire for the input, but how much larger?
any insight, advice and direction is much appreciated.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Feb13-09, 12:57 PM   #2
Running inverters in parallel is possible if you synchronise them. If you are off by a few degrees in phase, then you can blow them up.
Building a 5kw inverter is a different ball game. You have blow the schematic of a 1 kw inverter out of proportions. If are you new to electronics I wouldn't attempt building such an inverter as a first project.
Here is a list of different wire gauges, and how many amps they handle
http://www.powerstream.com/Wire_Size.htm
Thread Closed
Thread Tools
Similar Threads for: generator questions
Thread Forum Replies
The Homopolar Generator: Unanswered Questions Electrical Engineering 4
Flywheel Generator - Split from Propane Solar Collector/Generator Thread Mechanical Engineering 52
AC Generator Advanced Physics Homework 3
EASY Multiple concept questions- How does a loop of wire in a generator produce AC Introductory Physics Homework 0
HELP on DC Generator Electrical Engineering 2
