Is an Uncountable Probability Space with a Full Power Set Sigma-Algebra Viable?
  • Context: Graduate
  • Thread starter Thread starter mag487
    Infinite
The discussion revolves around the viability of an uncountable probability space where the sigma-algebra is the full power set of the space. Participants explore the implications of this setup within the context of measure theory and probability, examining specific constructions and theoretical limitations.
  • One participant proposes a probability space defined by infinite sequences of coin flips, suggesting a specific method to assign probabilities based on initial segments of sequences.
  • Another participant references the construction of the Vitali set to argue that a measure defined on all subsets of R cannot satisfy certain properties, implying a similar issue may arise in the proposed probability space.
  • A different participant introduces the concept of eventually constant sequences, questioning the probability measure's behavior on this set and its complement.
  • One participant notes the complexity of the problem, mentioning measurable cardinals and the uncertainty surrounding the provability of the existence of such a probability space within ZFC (Zermelo-Fraenkel set theory with the Axiom of Choice).
Participants express differing views on the feasibility of the proposed probability space, with some suggesting inherent contradictions and others exploring specific cases. The discussion remains unresolved, with no consensus on the viability of the construction.
Participants highlight limitations related to the properties of measures, the implications of the Axiom of Choice, and the complexities introduced by uncountable sets. The discussion reflects ongoing uncertainties and assumptions regarding the foundational aspects of measure theory.
mag487
Hi, I'm new here. I'm trying to teach myself measure theory and probability and recently wanted to find an example of a probability space (X, A, P) where X is uncountable and the sigma-algebra A is the entire power set of X. Here was my idea: let X be the set of all strings c1c2c3... for [tex]c_{i} \in \{ 0, 1\}[/tex], thought of as an infinite sequence of coin flips (with 1 corresponding to heads and 0 to tails), and A = X's power set. For x in X, define the n-restriction xn of x as the string of the first n digits of x. Furthermore, for S in A, define Sn := {xn : x is in S}. Finally, define [tex]P (S) := lim_{n\rightarrow\infty} card(S_{n})/2^{n}[/tex], i.e., the probability of S is the long-term proportion of the initial segments of the members of S to all possible initial segments.
I wanted to prove that (X, A, P) is a probability space. I thought I found a (rather torturous) proof of this claim, but got some initial results that led me to think my proof must have gone wrong somewhere. But before I type out my whole line of reasoning, does anyone already know for sure if the above triplet satisfies the criteria of a probability space? Thanks in advance!
The construction of the Vitali set shows that there's no measure m defined on all subsets of R satisfying sigma-additivity, m(T(S)) = m(S) for any translation T, and m([0,1]) = 1. I think you can mimic that construction for your set to show that it too won't work.
Regard X as functions from N to {0,1}. Define a relation ~ on X by:
x~y iff x and y disagree on a finite subset
It's clear that ~ is an equivalence relation. Let [x] denote the equivalence class of x. Invoking the Axiom of Choice, there exists a set R consisting of exactly one representative from each equivalence class. If S is a finite subset of N, x in X, define xS as follows:
xS(n) = x(n) if n is not in S
xS(n) = 1 - x(n) if n is in S
Define RS = {xS : x in R}
It's clear that if S and T are distinct finite subsets of N, then RS and RT are disjoint, and moreover
[tex]\bigcup _{S \in [\mathbb{N}]^{<\omega}}R_S = X[/tex]
where [itex][\mathbb{N}]^{<\omega}[/itex] is the set of finite subsets of N. The union above is a countable union since there are countably many finite subsets of N, and it's a union of disjoint sets. So
[tex]1 = P(X) = P\left (\bigcup _{S \in [\mathbb{N}]^{<\omega}}R_S\right ) = \sum _{S \in [\mathbb{N}]^{<\omega}} P(R_S)[/tex]
It's not hard to see that P(RS) = P(R) for all finite S. So the right hand side is P(R) added to itself countably many times. If P(R) is 0, then the right side is 0, contradicting the fact that the left side is 1. If P(R) is non-zero, then the right side is infinity, contradicting the fact that the left side is 1.
So P isn't defined at R.
Aha, here's the problem.
The key feature of this probability measure is that it's insensitive to what happens 'at infinity'. So, let's do something weird there.
Let S be the set of all eventually constant sequences.
What is P(S)? P(X-S)?
Actually, the problem you're trying to solve, mag487 is not remotely easy. Look up measurable cardinals. I'm just starting to understand this area of set theory, but the existence of "a probability space (X, A, P) where X is uncountable and the sigma-algebra A is the entire power set of X" is something that's either:
i) not known to be provable from ZFC and not known to be disprovable from ZFC,
ii) known to be neither provable nor disprovable from ZFC, or
iii) something like the above two possibilities.
