What is the Limit of (4[(SQRT(x+2)) – (SQRT2))]/x as x approaches 0?
  • Context: Undergrad
  • Thread starter Thread starter ladyrae
    Limit
The discussion revolves around finding the limit of the expression (4[(SQRT(x+2)) – (SQRT2))]/x as x approaches 0. Participants explore various methods for evaluating this limit, including analytic techniques and numerical estimation.
  • Homework-related
  • One participant estimates the limit using a table and suggests it approaches 1.414.
  • Another participant proposes using the method of multiplying by a conjugate as a first instinct.
  • A different participant mentions that L'Hôpital's rule is applicable for this limit.
  • Another participant agrees that L'Hôpital's rule is valid but also emphasizes that algebraic methods could be used to find the limit, suggesting the multiplication by the conjugate of the numerator.
  • Concerns are raised about the consistency between the numerical and analytical results, indicating that discrepancies might suggest an error in calculations.
Participants express differing preferences for methods to solve the limit, with some advocating for L'Hôpital's rule and others favoring algebraic manipulation. No consensus is reached on the preferred approach.
Participants note that the limit can be approached through multiple methods, and there is uncertainty regarding the accuracy of the numerical estimate compared to analytical results.
This discussion may be useful for students learning about limits in calculus, particularly those exploring different methods for evaluating limits analytically and numerically.
ladyrae
Help! Limit Problem
Find the limit by analytic methods:
lim x->0 (4[(SQRT(x+2)) – (SQRT2))]/x
The first part of the problem asked me to estimate the limit by using a table and I came up with 1.414.
I tried using the limit laws and came up with SQRT((4)(2))/(0+ SQRT((4)(2)))=1
Any suggestions?
Did you try multiplying a conjugate? That would be my first instinct.
Actually, my very first instinct would be to use L'Hospital's rule but I am guessing y'all haven't done that yet...?
L'Hôpital's rule works for this limit.
EDIT: It seems that someone else answered before me...I knew I shouldn't have wasted time trying to remember how to type an "o" with a circumflex.
L'Hôpital's rule should work, but it's still possible to find the limit with algebraic methods (and that might be how ladyrae is expected to do it).
We want to find:
[tex] \lim_{x\rightarrow 0} \frac{4(\sqrt{x+2} - \sqrt{2})}{x}[/tex]
I agree with Math Is Hard: I would multiply the top and bottom by the numerator's conjugate, like this:
[tex] \left(\frac{4(\sqrt{x+2} - \sqrt{2})}{x}\right)<br /> \left(\frac{\sqrt{x+2} + \sqrt{2}}{\sqrt{x+2} + \sqrt{2}}\right)[/tex]
Expanding that out, you should be able to plug in zero and find the limit directly.
Also note that your analytic result should be close to your table result (what you get from plugging in values exceedingly close to zero, like 0.000001). If you get 1.414 numerically and 1 analytically, you've probably made a mistake.
MC: Your circumflex "o" looks very elegant however. I think it was worth the trouble!
