Reviewing a Failed Assignment: Evaluating the Limit
  • Context: Undergrad
  • Thread starter Thread starter ladyrae
    Assignment Limit
The discussion revolves around evaluating the limit of a mathematical expression as x approaches -1. Participants are reviewing an assignment that did not yield the expected results, focusing on the correct approach to simplifying and calculating the limit.
  • Homework-related
  • One participant proposes that the limit evaluates to -1/2 after reducing the expression.
  • Another participant asserts that the correct answer is 3/4, suggesting the multiplication of the numerator and denominator by (x+3) to simplify the expression.
  • A third participant agrees with the 3/4 result and suggests moving (x+1) into the numerator to facilitate simplification, indicating that this method may be simpler.
  • One participant offers a method to verify the limit by substituting a value close to -1 into the original expression.
  • A participant inquires about the notation used in the mathematical expressions, indicating a lack of familiarity with the format.
  • Another participant explains that the notation is LaTeX markup, providing a link to a resource for learning more about it.
There is disagreement regarding the correct evaluation of the limit, with some participants supporting the answer of 3/4 while another claims it is -1/2. The discussion remains unresolved as multiple competing views are presented.
Participants express uncertainty about the simplification steps and the correct application of mathematical operations, indicating that assumptions about the expressions may vary.
ladyrae
I’m reviewing an assignment that didn’t go so well
Evaluate limit
lim x->-1 (1/2+(x/(x+3))/(x+1)
I reduced to (1+2x)/2 = -1/2
I originally had x-1/x=2 but i redid the problem as above
Is this correct?
No, the answer is 3/4.
[tex]\frac{0.5+\frac{x}{x+3}}{x+1}[/tex]
You want to multiply both the numerator and denominator by x+3 so that you can get rid of the fraction in the numerator. Then it should be easy to factor x+1 out of both the numerator and denominator.
That's not the correct answer. You want to find:
[tex] \lim_{x\rightarrow -1} \frac{\frac{1}{2} + \frac{x}{x+3}}{x+1}[/tex]
Move the (x+1) up into the numerator:
[tex] \frac{1}{2(x+1)} + \frac{x}{(x+3)(x+1)}[/tex]
Get a common denominator and add these two terms together, and you should see that the x+1 will fall out of the top and bottom.
Edit: master_coda's way of multiplying the top and bottom by (x+3) is probably simpler.
You should get 3/4, like master_coda said.
Like I said in another of your threads, you can check your work by plugging in a value close to -1 into your original expression (like -0.99999). Your numerical result should be close to the analytical answer. If they aren't, you've probably made a mistake.
Notation
I'm a newbie ...
Are you using software to write the equation in that format?
It's LaTeX markup (code), built into these forums. Check out this thread:
https://www.physicsforums.com/showthread.php?t=8997
The best way to learn is by example. You can click on any equation in any thread and see what the author typed to create it.
  • · Replies 17 ·
