Solid Conducting sphere inside a conducting spherical shell
The problem involves a solid conducting sphere with a radius of 0.7 cm and a charge of -7.3 pC, placed inside a conducting spherical shell with an inner radius of 2.8 cm and an outer radius of 5 cm, which has a net charge of 27.9 pC. The charge on the inner surface of the shell, denoted as Q′2, is +7.3 pC, while the charge on the outer surface, Q′′2, is calculated to be +20.4 pC. This arrangement ensures that the electric field inside the conducting shell remains zero, as required by electrostatic equilibrium.
  • Understanding of electrostatics and charge distribution in conductors
  • Familiarity with Gauss's Law and its application in electrostatics
  • Knowledge of electric fields and their behavior in conductive materials
  • Basic principles of charge conservation in electrostatic systems
  • Study Gauss's Law and its implications for charge distribution in conductors
  • Learn about electrostatic shielding and its applications in practical scenarios
  • Explore the concept of electric fields in conductors and their equilibrium states
  • Investigate the behavior of charges in various geometrical configurations of conductors
Students and professionals in physics, electrical engineering, and anyone interested in understanding electrostatics and charge behavior in conductive materials.
phymateng
Consider a solid conducting sphere with a radius 0.7 cm and charge −7.3 pC on it. There is a conducting spherical shell concentric to the sphere. The shell has an inner radius 2.8 cm(with 2.8 cm > 0.7 cm) and outer radius 5 cm and a net charge 27.9 pC on the shell. Denote the charge on the inner surface of the shell by Q′2 and that on the outer surface of the shell by Q′′2. Find the charge Q′′2. Answer in units of pC
I got this problem wrong and don't know why.
Shouldn't Q''2 be 0 since the sphere is negative on the surface and attracting the positive charges on the inner shell. The shell should be stable since its a conductor and its Electric field inside is=0. Therefore, the Charge outside the shell is 0.
Conceptually I thought
inside the shell should be the opposite of the charge of the sphere. Since the sphere is negative, then the charge Q'2 inside surface of the shell is same charge but positive. So Q inside shell + Q'2 inside surface of shell = Q''2 outside shell (of whole sphere). For the conducting sphere to be in equilibrium Q''2 should just be 0.
The essential point in this problem is that the electric field inside a conducting object is zero when the charges are in equilibrium. Therefore the charge on the outer spherical shell arranges itself so that it cancels the electric field due to the inner solid conducting sphere. That means there will be some charge left over and this charge will flow to the outer surface. Remember free charge on a conductor flows to the outer surface. (Gauss's law is used to prove this.)
Q''2=207.9-7.3=20.4 pC;
Q'2=7.3 pC;
14K
