Why Does Shear Increase with Distance in Torque-Shear Calculations?
  • Thread starter Thread starter apointyrodent
    Concept
The discussion centers on the torque-shear equation, specifically the relationship between shear stress and distance from the center of gravity (CG) in rivet patterns under non-symmetric loads. Participants clarify that the Tr/J formula is used to calculate shear in individual bolts, revealing that shear stress increases with distance from the CG. This is counterintuitive as one might expect that greater distance would require less force to resist torque. However, it is established that within a bolt pattern, the highest shear stress occurs at the bolt farthest from the center of rotation, as demonstrated by the equation T*r/J.
  • Understanding of torque-shear calculations
  • Familiarity with the Tr/J formula
  • Knowledge of shear stress in mechanical engineering
  • Concept of center of gravity (CG) in structural analysis
  • Study the implications of the Tr/J formula in various loading scenarios
  • Explore shear stress distribution in non-symmetric load applications
  • Learn about the effects of distance from the center of rotation on shear forces
  • Investigate bolt pattern design considerations for torque applications
Mechanical engineers, structural analysts, and students studying torque-shear relationships in rivet patterns and bolt design.
apointyrodent
For some reason I am having a hard time visualizing the torque-shear equation, specifically when it comes to finding shear in rivet patterns with a non-symmetric load. We have been using the Tr/J formula to find the shear in the individual bolts. However, with this equation with increasing distance from the CG the shear also goes up. This seems counter-intuitive.
For example.. think about torquing a bolt. The farther you are from the center of rotation the less force is required to produce a given torque... so why is the reverse not true? I.e. "Given a constant torque, the farther you are from torque center the less force required to resist it, therefore less stress is induced?"
I've never had a problem with this before but it's been bugging me today for some reason. Thanks.
Your second paragraph is an analogy for comparing two bolt (rivet) patterns, whereas your first paragraph is a question regarding one given bolt pattern. Within a given bolt pattern, the highest shear stress (and therefore shear force) occurs on the bolt having the largest distance from the center of rotation, which is shown by the relation T*r/J.
18K
  • · Replies 42 ·
  • · Replies 25 ·
31K
