Thread Closed
*software needed*
Share Thread
Feb16-09, 04:06 AM   #1
*software needed*
Hi
I need a software for designing airfoil that alows changing the choard size and printing. If you know any please tell me.
Btw do you know any refrence for low Reynolds number (about 50000)?
I wanna choose NACA7610 for my glider but I don't know exactly how it behaves at low Reynolds number. PLEASE HELP
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb16-09, 05:43 AM   #2
Most drawing progams will allow you to draw an airfoil and change the chord size and then print the result. I'm not sure what you're asking here.
I'm also not sure that 50000 is a low Reynold's number, that seems to be very definitely in the turbulent region.
Laminar 0>Re>3000
Transition 3000>Re>4000
Turbulent Re>4000
If you need CFD software, there is an opensource software called openfoam, but it only runs on Linux. Check wikipedia for other CFD software links.
Feb16-09, 09:45 PM   #3
Quote by redargon View Post
Laminar 0>Re>3000
Turbulent Re>4000
These Re numbers are generally true for pipe flow. Do you have any sources saying they are also true for airfoil sections? I would like to see this if you have it.
Feb17-09, 02:21 AM   #4
*software needed*
nope, no sources. What you say is true, thanks for pointing that out, do you have anything useful for the OP?
Feb17-09, 02:29 AM   #5
you may use designfoil software which is freely available by searching google
Feb17-09, 12:28 PM   #6
He could try xfoil.
Feb23-09, 11:05 PM   #7
Quote by Cyrus View Post
He could try xfoil.
I downloaded xfoil but I can't open it
Apr11-09, 10:06 PM   #8
A professor in the Department of Aerospace Engineering at the University of Illinois at Urbana-Champaign lists several resources on his page:
http://www.ae.uiuc.edu/m-selig/ads.html
His list includes XFOIL, as already mentioned by Cyrus.
Apr17-09, 10:11 AM   #9
Did you download the correct version of X-Foil?
here is the one i am using
http://web.mit.edu/drela/Public/web/xfoil/xfoil6.96.zip
Runs windows, xp/vista and is easy to use/run
You may have downloaded the source that needs compiling?
Jun2-09, 03:10 PM   #10
helo cyrus,check this link
01.http://www.zenithair.com/kit-data/ht-87-5.html
Jun2-09, 03:55 PM   #11
Recognitions:
There is nothing in those articles that ties the typical piping Reynolds numbers to airfoil usage.
Jun2-09, 07:59 PM   #12
Quote by jags View Post
I'm not sure what you want me to check out about it.
Feb22-10, 07:02 PM   #13
XFLR5 and profili is also good software where we could analyse more different aerofoils
Feb22-10, 09:08 PM   #14
I've said this before, but it is fairly easy to write a vortex panel program in Matlab to calculate lift coefficients. Anderson's aerodynamics book covers this stuff in detail.
Feb28-10, 05:55 PM   #15
Quote by Brian_C View Post
IF you can afford the $1900 price tag.
Thread Closed
Similar discussions for: *software needed*
Thread Forum Replies
C++ software Programming & Comp Sci 5
PSpice software needed :( Engineering Systems & Design 3
Software Introductory Physics Homework 2
Software General Math 2
Video Editing Software Needed!!! Computing & Technology 8
