| Thread Closed |
Question about two circular concentric coils |
Share Thread | Thread Tools |
| Feb17-09, 11:46 AM | #1 |
Two circular coils are concentric and lie in the same plane. The inner coil contains 110 turns of wire, has a radius of 0.010 m, and carries a current of 5.6 A. The outer coil contains 190 turns and has a radius of 0.014 m. What must be the magnitude of the current in the outer coil, such that the net magnetic field at the common center of the two coils is zero? 2. Relevant equations B=(constant)IN/2R 3. The attempt at a solution Ok so I have I1=5.6 A R1=.010 m N1=110 R2=.014 m N2=190 I2=? I think that I have to use that equation somehow and set them equal to each other, but I'm lost after that. Perhaps I'm using the wrong equation entirely? Any help is much appreciated!! Edit: Do I just solve for B1 and then set that equal to the equation for the 2nd coil (only make it negative)? 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Feb17-09, 12:26 PM | #2 |
Recognitions:
You should be able to figure the magnitude of the field from the first coil from what you're given.
Then they want to know what opposing current using the parameters of the other coil is needed to null out the B field at the center. I find it easiest to keep it as variables of the 2 loops and then plug in the numbers at the end to solve for the one that you need. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Question about two circular concentric coils
| Concentric Spheres Capacitance Question- How to use area | Introductory Physics Homework | 1 | ||
| concentric cylinders E field | Introductory Physics Homework | 4 | ||
| [SOLVED] another concentric sphere electric field question | Introductory Physics Homework | 3 | ||
| Air core Coils vs. Metal core coils | Electrical Engineering | 1 | ||
| two concentric spheres | Introductory Physics Homework | 8 | ||
