Ordinary Differential Equation by substitution.
The discussion focuses on solving the ordinary differential equation (ODE) dy/dx = (x+3y)/(3x+y) using substitution methods. The initial attempt involved transforming the equation into a separable form, but the user faced challenges in simplifying the expression. A more effective approach suggested integrating both sides with respect to their respective variables and equating the resulting arbitrary functions. This method leads to the implicit solution h(x, y) = 0, which can be verified through implicit differentiation.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with integration techniques
  • Knowledge of substitution methods in differential equations
  • Ability to perform implicit differentiation
  • Study integration techniques for ordinary differential equations
  • Learn about substitution methods in solving ODEs
  • Explore implicit differentiation and its applications
  • Research the method of characteristics for solving first-order PDEs
Students and educators in mathematics, particularly those focusing on differential equations, as well as anyone looking to enhance their problem-solving skills in calculus.
WREX88
I have to solve the given differential equation by using an appropriate substitution...
I used algebra to make the equation (3x+y)dy - (x+3y)dx = 0
then made x = vy and dx = vdy + ydv.
then plugged into get (3vy+y)dy - (vy+3y)(vdy+ydv)
and now I'm looking for a common factor to cancel and I'm stuck, any help? Am I even headed in the right direction...thanks.
It doesn't seem you're heading in the right direction. Here's what I would try.
Starting with this equation,
(3x+y)dy = (x+3y)dx
integrate the left side with respect to y. Since you're integrating with respect to y, you'll end up with whatever you get plus an arbitrary function of x alone.
Then, integrate the right side with respect to x, similar to above. This time around you'll need to include an arbitrary function of y alone.
The left and right sides have to be equal for all pairs of (x, y) values, so you can equate the arbitrary functions of x or y on either side with what's on the opposite side.
This should give you the equation h(x, y) = 0.
To check your answer, take the derivative implicitly.
Looking at the symmetry of "3x+ y" and "x+ 3y", which has "average" value 2x+ 2y= 2(x+ y), let u= x+ y and v= x- y. Then x= (1/2)u+ (1/2)v and y= (1/2)u- (1/2)v, dx= (1/2)du+ (1/2)dv, dy= (1/2)du- (1/2) dv. Put those into the equation. you should wind up with udv= vdu.
  • · Replies 25 ·
