Simple circuit with a transistor
  • Thread starter Thread starter dancavallaro
    Circuit Transistor
The discussion revolves around a circuit involving a common-emitter amplifier configuration with an NPN transistor. The original poster describes a voltage divider connected to the base of the transistor and seeks to calculate the current through a load resistor, R_load, while questioning the dependency of this current on R_load's value.
  • Participants explore the relationship between the base voltage and the emitter voltage, questioning the constraints on R_load and its impact on the current through the circuit. There are discussions about the assumptions made regarding the transistor's behavior and the implications of the voltage divider setup.
The conversation is ongoing, with various interpretations being explored. Some participants offer insights into the implications of the voltage levels in the circuit, while others express confusion about the constraints on R_load and the assumptions regarding the transistor model being used.
There is a lack of specifications regarding the transistor's characteristics, such as its beta value, which some participants note may affect the analysis. The original poster's assumptions about the base current and the forward-bias condition of the transistor are also under scrutiny.
dancavallaro
Here's a crude description of the problem until my attachment is approved: it's essentially a voltage divided connected to a common-emitter amplifier (I think). There's a +10 V line connected via an 8.4 kOhm resistor to the base of the NPN transistor, and a 1.6 kOhm resistor connecting the base to ground. Then there is a resistor R_load connecting the +10 V line to the collector of the transistor, and a 1.0 kOhm resistor connecting the emitter of the transistor to ground. I'm supposed to calculate the current through R_load, and say whether the result depends on the value of R_load. We're assuming the simplest model of a transistor: the base current is always 0, and when the B-E junction is forward-biased at least 0.6 V, then current flows from C to E, where V_E = V_C - 0.6.
When V_BE > 0.6:
I_C = I_E and V_E = V_C - 0.6
I think V_B = V_in*(1.6/(1.6+8.4)) = 1.6 V, so the B-E junction is forward-biased, and current flows from the collector to the emitter. Then V_C = 10 - I_C*R_load, but I_C = I_E so V_C = 10 - I_E*R_load. Then V_E = V_C - 0.6, so V_E = 9.4 - I_E*R_load. Then I_E = (9.4 - I_E*R_load)/1000, so I_E = 9.4/(1000+R_load). But I don't think this is right, because I'm pretty sure the current through R_load doesn't depend on the value of R_load. What am I doing wrong here?
Isn't your Rload constrained to be greater than 9kΩ ?
If the current through the 1kΩ resistor is greater than 100 ma doesn't the C-E open because the base is at 1.6v?
I'm not sure I follow.. why is R_load constrained to be greater than 9kΩ?
Maybe I'm not understanding, I just thought that you said the voltage from the base to the emitter needed to be greater than .6v. Since the base is held at 1.6v I thought that meant the Ve couldn't be greater than 1v. So long as the Rload is greater than 9kΩ then the Ve will be <1v.
I shouldn't comment, having done nothing with transistors for many years, but it seems to me the absence of any specs on the transistor - such as its beta - means a crude answer is desired. I was taught that the emitter-base voltage on a working transistor is always 0.6 V. The voltage divider on the base puts the base at 1.6 V. So there must be 1 volt on the 1k emitter resistor. That determines the current regardless of the collector resistor!
That's right - we're using a very simple model right now, where beta is ignored and we assume that no current flows from base to emitter. What you say makes sense though - so if there's 1 volt on the 1k emitter resistor, then I_E = I_C = 1/1000 = 1 mA, regardless of the value of R_load.
14K
