Thermal efficiency in a reversible cycle for an ideal gas pV diagram
The discussion revolves around calculating the thermal efficiency of a heat engine operating through a reversible cycle involving an ideal gas, as represented on a pV diagram. The problem specifies parameters such as the number of moles, temperatures, and volumes at various points in the cycle.
  • Participants discuss the calculations for temperature and pressure at different points in the cycle and the heat absorbed or released during various paths. There are questions about the inclusion of heat for the isothermal process and the correct identification of heat absorbed versus heat expelled.
Some participants have offered guidance on the calculations and the interpretation of heat transfer in the context of the cycle. There is an ongoing exploration of how to correctly account for the heat and work done in each segment of the cycle, with multiple interpretations being considered.
Participants note the importance of understanding the distinction between heat absorbed and heat expelled, as well as the implications of constant temperature processes in the context of the first law of thermodynamics. There is also a mention of potential misconceptions regarding heat transfer during isothermal expansion.
clairez93
A heat engine takes 4.0 moles of an ideal gas through the reversible cycle abca, on the pV diagram, as shown. The path bc is an isothermal process. The temperature at c is 600 K and the volumes at a and c are 0.04 m^3 and 0.10m^3, respectively. The molar heat capacity at constant volume, of the gas, is 30 J/mol*K. In the figure, the thermal efficiency of the engine is closest to:
a) 0.07
b) 0.10
c) 0.15
d) 0.22
e) 0.30
[tex]P = nRT[/tex]
[tex]Q = nC_{v}\Delta[/tex]T
[tex]Q = nC_{p}\Delta[/tex]T
W = P[tex]\Delta[/tex]V
[tex]W = nRT ln \frac{V_{f}}{V_{i}}[/tex]
[tex]e = \frac{W}{Q_{h}} = 1 - \frac{Q_{c}}{Q_{h}}[/tex]
First, I calculated the temperature and pressures at points a, b, and c using PV = nRT.
Point A:
V = 0.04 m^3
T = 600 K
P = (4)(8.31)(600) / 0.04 = 498000 Pa
Point B:
V = 0.04 m^3
T = PV / NR = (199440)(0.04) / (4)(8.31) = 240 K
P = 199440 Pa
Point C:
V = 0.10 m^3
T = 600 K
P = nRT / v = (4)(8.31)(600) / .10 = 199440
Then I calculated the heat absorbed on the path ab in kJ:
Q = (4)(30)(600-240) = 43200 ~ 43
Then I calculated the heat absorbed on the path ca in kJ:
Q = (4)(30 + 8.31)(-360) = -55166.4 ~ -55
Then I calculated the work done on the path bc in kJ:
(4)(8.31)(600)ln (.10/.04) = 18274.5 ~ 18
[/tex]
Then I calculated the work done on the path ca in kJ:
(199440)(.04-.10) = -11966.4 ~ -12To calculate the thermal efficiency, I tried this:
[tex]e = \frac{W}{Q_{h}}[/tex] = (18-12) / (43 -55) = -0.5
Obviously that cannot be correct.
The correct answer is B. 0.10.
How should I calculate the efficiency?
Please let me know, this problem has been plaguing me forever!
Any help?
Please? I hate bump posts, but I'm kind of desperate on this one.
You need to include Q for path bc.
Also, looking again at your derivation:
I don't think Qh would include the -55 kJ of path ac; wouldn't that be part of Qc instead?
Since there is no change in temperature from bc, wouldn't there be no heat for bc?
That's a common misconception.
If no heat were added, an expanding gas will cool because it is doing work (i.e. losing energy) to the environment. To maintain temperature, it is necessary to add heat equal to the amount of work done in path bc.
Has your class covered the Carnot Cycle? Note the distinction between constant temperature and adiabatic (no heat exchange) paths in that cycle.
Hope that helps.
Oh I see, I'm not sure how to calculate the amount bc? Would it just remain the same as in ab?
No (or at least I don't see why it would).
If you can figure out both the work done and the energy change along bc, then you can use the 1st law to calculate the heat.
So the heat would be just equal to the work done right, because there is no change in internal energy?
Yes.
Using that info, here's what I tried:
[tex]Q_{ab} = +43[/tex]
[tex]Q_{bc} = +18[/tex]
[tex]Q_{ca} = -55[/tex]
[tex]W_{ab} = 0[/tex]
[tex]W_{bc} = +18[/tex]
[tex]W_{ca} = -12[/tex]
So first, I tried adding all the heat up, and got a value of 6. Then I added up all the work and got 6. 6/6 = 1 Obviously wasn't going to work.
I guessed that because on the path ca, the heat is negative, that wouldn't be Qh because it would be the heat expelled.
So then what I did was just took 43+18 for Q, which comes out to be 61, and then took the net work of 6, and did 6/61 = .098361, which I think matches to the answer of .1.
I just want to make sure my logic was correct on this.
Yes, you've got it. :smile:
Efficiency is (total work) / Qh
Qh refers to any heat absorbed. Presumably, this is the energy cost to operate the heat pump, whether it's from burning coal or gasoline or nuclear fuel, etc.
Qc is any heat that is given off, and is not a part of the "energy cost".
Thank you very much! :D
