What gas's temperature increases as it decompresses?
  • Context: Undergrad
  • Thread starter Thread starter noblethewhite
    Temperature
The discussion revolves around the phenomenon of gas temperature changes during decompression, particularly focusing on whether any gas can exhibit an increase in temperature as it decompresses. The conversation touches on concepts from thermodynamics, including the Joule-Thomson effect and the conditions under which gases may behave differently than expected.
  • Some participants question the existence of a gas that increases in temperature during decompression, suggesting that it may involve a reaction.
  • References are made to the Joule-Thomson effect, with some participants noting that the temperature change during expansion can be negative at high temperatures.
  • One participant discusses the difference between free decompression and the Joule-Thomson process, emphasizing that work is done on the gas in the latter case, which can lead to heating.
  • Another participant mentions that real gases exhibit different behaviors compared to ideal gases, particularly under high pressures and temperatures, which can affect temperature changes during expansion.
  • There is a claim that hydrogen is a gas that can heat up during decompression, particularly in industrial contexts where rapid pressure drops can lead to ignition risks.
Participants express differing views on whether a gas can increase in temperature during decompression, with some supporting the idea under specific conditions while others remain skeptical. The discussion does not reach a consensus on a definitive answer.
Participants highlight the importance of conditions such as pressure and temperature, as well as the specific characteristics of real gases versus ideal gases, which complicate the understanding of temperature changes during decompression.
noblethewhite
I'm not sure if this is where this question should go, but it can't really follow the template in the homework section. I've looked on search engines, phrasing this question differently but can't seem to find the answer. It would be the exception to Charles Law, I believe.
Science news on Phys.org
What makes you think that such a single gas exists? Or is a reaction involved?
See: "free expansion, and/or Joule-Thomson (also, Thompson), or Joule-Kelvin, or Kelvin-Joule coefficient/effect."
Ah, I was considering
[tex]\left(\frac{\partial T}{\partial V}\right)_{S,N}[/tex]
which is never positive for a gas (a positive value corresponds to a gas heating during decompression). However, in the Joule-Thomson expansion it looks like we're considering
[tex]\left(\frac{\partial T}{\partial P}\right)_{H,N}[/tex]
which can be negative at high temperatures (and a negative value corresponds to a gas heating during decompression). That's interesting, Bystander, I hadn't heard of the Joule-Thomson inversion temperature before, thanks.
I looked into this a little more because it's not intuitive (to me, at least) how the temperature of a gas could increase during "decompression." We could use that word to describe a Joule-Thomson experiment (constant and unequal pressures on either side of a porous plug), but it seems more accurate to say that we are pushing the gas irreversibly through the plug, and we are definitely doing work on the system. This, of course, has a different connotation than a free decompression, in which no positive work enters the system (and the gas may end up doing work on the environment, decreasing the temperature of the gas).
In the Joule-Thomson arrangement, we do work on the gas before it enters the plug, and recover that energy as work when the gas expands on the other side. In the case of an ideal gas, the amounts are equal and the temperature doesn't change. In the case of a real gas, atomic/molecular repulsion increases at high pressures and temperatures, and we must do more work on the upstream side to obtain a given pressure. This excess work ends up heating the gas.
I'm in a process technology course and the instructor asked this question as one of his bonus questions. There's suppose to be an actual gas that does this. I'm not really that far in my knowledge of physics yet but I'm guessing that would be the principle behind this gas's reaction to pressure.
Lots of gases --- long's they're above their J-T inversion temperatures. Couple with J-T inversion Ts well below room T are technically "difficult" to liquify. Hint enough for you?
Well found out the answer. That is the principle behind it, but the answer he was looking for is hydrogen. Apparently in plants its a big worry if any pipe or container containing hydrogen leaks, b/c if it does the rapid drop in pressure will cause the hydrogen to heat up and ignite. So you can imgaine the problems that would cause.
  • · Replies 20 ·
  • · Replies 23 ·
  • · Replies 135 ·
10K
