Electric field of a point charge
The problem involves calculating the net electric field at the center of a square formed by four point charges, three positive and one negative, each with a magnitude of 3.1 x 10-12 C. The square has sides of 5.3 cm.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the setup of the electric field equation and the importance of converting units from centimeters to meters. There are attempts to calculate the electric field using the formula E=k*abs(q)/r2, and questions arise about the correct distance to use in the calculations.
Participants are actively engaging with the problem, offering hints about the symmetry of the charge arrangement and the need to consider the vector nature of the electric fields from each charge. Some guidance has been provided regarding the combination of the electric field vectors, but no consensus on a final solution has been reached.
There is a noted confusion regarding the calculation of distances and the resultant electric field from multiple charges, as well as the need to sum the contributions from all four charges rather than just one.
Snowman2526
Four point charges have the same magnitude of 3.1 x 10-12 C and are fixed to the corners of a square that is 5.3 cm on a side. Three of the charges are positive and one is negative. Determine the magnitude of the net electric field that exists at the center of the square.
E=k*abs(q)/r^2
I set up the equation E=(8.99*10^9)(3.1*10^-12)/(3.75^2).
1.98*10^-3 is not correct
A post I was reading mentioned using the formula E=kq/r...which can be found here: https://www.physicsforums.com/showthread.php?t=151884
Now, my book has a similar picture which mentions an E24 vector pointing at the negative point charge, I'm not sure what I'm doing wrong...any help is welcome.
Welcome to PF.
The charges that are the same will off set each other. But the pair that are the opposite charge will have the effect of adding at the center. Sounds like the |ΣE| will be 2*|E|. Because the other 2 net to 0.
Convert the cm to meters.
You have four E vectors - all the same magnitude but different directions - to add.
Begin with a diagram! Symmetry may help!
you are correct delphi, its kind of embarassing, but i forgot to convert cm to m. but I am still getting the wrong answer.
After plugging the sides of my square into the Pythagorean theorem i get .075...but i want to divide that number by 2, giving me the .0375.
my equation now reads:
E=(8.99*10^9)(3.1*10^-12)/.0375^2
I got 19.82 N/C but the stupid wiley site tells me that I am wrong.
Is there something wrong with the way I am setting up my equation?
You are apparently only calculating the |E| from one of the point charges.
They asked for the Σ of the E.
Looks okay (I disagree only in the 4th digit) but you aren't finished yet!
LowlyPion gave you a huge hint on how to combine the FOUR vectors, each of which have this magnitude. Diagram. FOUR arrows beginning on the center point, pointing away from the positive charges and toward the negative charge.
Aha! Thank you very much! Problem solved
