Electrical Field of a Charged set of Spheres
The problem involves calculating the electric field generated by two spherical shells with a common center, where one shell has a negative charge and the other has a positive charge. The specific distances from the center at which the electric field needs to be evaluated are provided.
  • The original poster attempts to calculate the electric field and electric flux for both shells but expresses uncertainty about how to combine the effects of the charges. Some participants suggest using Gauss' Law and focusing on the charge contained within a specific radius.
Participants are exploring different interpretations of how to apply Gauss' Law to the problem. There is a discussion about whether to consider the outer charge when calculating the electric field at certain distances. Some guidance has been provided regarding the application of the law, but the original poster continues to seek clarification on the concepts involved.
The original poster indicates confusion about the setup of the problem and the application of the relevant equations, particularly regarding the treatment of the charges and the distances involved.
Snowman2526
Two spherical shells have a common center. A -1.37 x 10-6 C charge is spread uniformly over the inner shell, which has a radius of 0.0422 m. A +5.86 x 10-6 C charge is spread uniformly over the outer shell, which has a radius of 1.60 m. Find the magnitude of the electric field at a distance (measured from the common center) of (a) 0.200 m (b) 0.100 m, and (c) 0.025 m.
Honestly I'm not sure how to set this equation up.
I have calculated the Electric Field of each sphere. the smaller is 6.92*106 and the larger is 2.06*104
I also calculated the Electric Flux each. The smaller being 6.54*104 and the larger being 6.63*105.
Now I'm not quite sure if I have to add the two spheres together, or what to do since the inside sphere is negatively charged.
This is a Gauss' Law question.
For (a) you imagine a sphere at with radius 0.2 and consider only the charge contained in it. The whole thing is spherically symmetric, so the E field will be the same everywhere on the surface of the sphere.
i'm sorry to necro bump my old thread but I still cannot get this problem. When you say imagine it with the radius .2...do i add it to the radius of the two circles? or is it a fresh radius and I just plug .2 into r for my equation.
On top of that, I am sitting with two variables because I can't find out what E is. Do I add the Coulomb charge of the two spheres or combine them somehow? I'm honestly not looking for someone to do it...I just can't grasp the concept for this problem.
Imagine a sphere with radius 0.2. The Law says E times the surface area of the sphere equals some constant times the charge INSIDE the sphere. So you just ignore the outer charge for part (a).
