Differential calculus, derivatives
The discussion revolves around finding the derivative of the function f(x) = 16x - x^-2 using first principles in the context of differential calculus.
  • The original poster attempts to apply the derivative formula but encounters discrepancies between their results and expected outcomes. Some participants question the interpretation of the function and suggest clarifying the expression for f(x). Others provide steps for applying the first principles method and inquire about the limit process involved.
The discussion is active, with participants providing guidance on the application of first principles and addressing errors in calculations. There is an acknowledgment of a mistake in the original poster's approach, and a correction has been noted, leading to a more accurate understanding of the derivative process.
There is a potential misunderstanding regarding the function's expression, which has led to confusion in the calculations. The original poster's attempts have revealed inconsistencies that are being explored in the discussion.
DERRAN
Find f'(x)= 16x - x-2 using first principles.
x
http://img153.imageshack.us/img153/8403/597137697c1f605c7a43d34qz4.png
I used dy/dx and got 2x-3 + 16 but I get something different when I use the formula I attempted several times and I can't get the same answer as the dy/dx.
Please need help!
Do you mean "find f'(x) if f(x)= 16x- x-1"? That's quite different from what you say!
If f(x)= 16x- x-2, then f(x+h)= 16(x+h)- (x+ h)-2
f(x+h)- f(x)= 16(x+ h)- 16x - (x+h)-2+ x-2
The first part of that is just 16x+ 16h- 16x= 16h.
The second part is
[tex]-\frac{1}{(x+h)^2}+ \frac{1}{x^2}[/tex]
[tex]= \frac{-x^2}{x^2(x+h)^2}+ \frac{(x+h)^2}{x^2(x+h)^2}[/tex]
[tex]= \frac{-x^2+ x^2+ 2hx+h^2}{x^2(x+h)^2}= \frac{2hx+ h^2}{x^2(x+h)^2}[/tex]
so
[tex]f(x+h)- f(x)= 16h+ \frac{2hx+h^2}{x^2(x+h)^2}[/tex]
Now, what is (f(x+h)- f(x))/h and what is the limit of that as h goes to 0.
you've lost a square from the denominator for no reason during your calc, they should work
Thanks sorry about that it works perfectly!
  • · Replies 25 ·
  • · Replies 105 ·
13K
  • · Replies 23 ·
