Integrating sin(x)/x using Integration by Parts
The discussion revolves around the integral of sin(x)/x, specifically the challenges associated with integrating this function using various methods, including integration by parts. Participants are exploring the nature of the integral and its evaluation techniques.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the difficulties of integrating sin(x)/x, with one noting that it cannot be expressed in closed form using elementary functions. There are inquiries about the context of the problem, including whether it is part of a larger assignment and the limits of integration. Some suggest using power series expansion for evaluation.
The conversation is active, with participants providing hints and exploring different approaches to the integral. Some guidance has been offered regarding the use of power series, but there is no explicit consensus on a single method or solution.
Participants are working under the constraints of a homework assignment that specifies multiple methods for evaluating the integral, including numerical techniques and analytical approaches. There is a mention of the integral's limits being from 0 to 1.
jackalsniper
i'm having troubles to integrate [tex]\int\frac{sin x}{x} dx[/tex]
could anyone help me with hints? i tried using integration by parts, but i see it as a never ending chain, sin will change to cos... and x^-1 will become -x^-2 and so on
That integral can't be expressed in closed form in terms of elementary functions. SinIntegral
i don't really understand that article, can u explain it please?
I doubt that I can provide a much better explanation than what is given in the article. It should be pretty self-explanatory provided you have at least a 2nd year university level math understanding.
Are you sure you are trying to evaluate the correct integral? Is this part of a larger problem? Have you come across special functions before?
no, it's a question that says,
compute the integral of (sinx / x) dx by means of
a. the trapezoidal rule
b. a three term gausian quadrature formulae.
c. simpson's 1/3 rule
d. determine the integral analytically.
i was thinking that part d. uses integration by parts to solve
Is it a definite integral? If so, what are the integration limits?
integrate from 0 to 1, sorry i forgot to include that
In that case, use the power series expansion for sine and integrate it term by term. You can either leave your answer as an infinite sum, or explicitly sum up the first 3-4 non-zero terms. Summing to order x^7 gives a result accurate to 6 decimal places.
It's too bad it wasn't from zero to infinity, that produces a nice exact answer:smile:
u mean like [tex]\int\stackrel{1}{0} \frac{sin x}{x} dx = x - \frac {x\stackrel{3}{}} {(3 \cdot 3!)} + \frac {x\stackrel{5}{}} {(5 \cdot 5!)} - \frac {x\stackrel{7}{}} {(7 \cdot 7!)} + - ...[/tex]?
Don't forget to substitute in the limits!
[tex]\int_0^1 \frac{sin x}{x} dx = \left[ x - \frac {x\stackrel{3}{}} {(3 \cdot 3!)} + \frac {x\stackrel{5}{}} {(5 \cdot 5!)} - \frac {x\stackrel{7}{}} {(7 \cdot 7!)} +...\right]_0^1[/tex]
You can write it as an infinite sum; [tex]\sum_{n=0}^{\infty} \frac{(-1)^n}{(2n+1)(2n+1)!}[/tex] or just evaluate the first few terms.
ok, thanks for the help, i appreciate it very much
  • · Replies 22 ·
  • · Replies 19 ·
