Electric field inside hydrogen atom.
The discussion focuses on calculating the electric field inside a hydrogen atom, which consists of a proton and an electron with a volume charge density described by the equation ρ = A * exp(-2r/a₁), where A is a constant and a₁ = 0.53 x 10-10 m is the Bohr radius. Participants emphasize the importance of hydrogen's electrical neutrality in determining the constant A by integrating the charge density over the atom's volume and setting the total charge to zero. The electric field can subsequently be derived once A is established.
  • Understanding of electric fields and charge distributions
  • Familiarity with the concept of volume charge density
  • Knowledge of integration techniques in physics
  • Basic principles of quantum mechanics related to atomic structure
  • Learn how to derive charge density functions for different atomic models
  • Study the application of integration in calculating electric fields
  • Explore the use of delta functions in representing point charges
  • Investigate the implications of electrical neutrality in atomic physics
Students and educators in physics, particularly those studying atomic structure and electrostatics, as well as researchers interested in charge distribution models within atoms.
onyx390
A hydrogen atom can be considered as having a central point-like proton of positive charge +e and an electron of negative charge -e that is distributed about the proton according to the volume charge density rho=A*exp(-2r/a_1). Here A is a constant, a_1 = .53x10^(-10)m is the Bohr radius, and r is the distance from the center of the atom. a) Using the fact that hydrogen is electrically neutral, find A. b) Then find the electric field produced by the atom at the Bohr radius.
I've been struggling at part a. Once I find A, I can just integrate and solve for the electric field. However, although I know that hydrogen being electrically neutral is what will help me solve this, I don't know what this implies. My main guess is that I set r equal to a_1. However, that still leaves the unknown of q. Can someone explain to me how hydrogen's neutrality is relevant? Once I figure that out, I'm sure that the problem will become much simpler for me. Thank you in advance.
The term "A" is probably going to be composed of two parts that add together.
Try thinking about how to use a combination of step functions (or delta functions) to represent the electron and proton. Arfken has a little bit of material on this.
If you have not had delta or step functions, I will try to think of other means. But I think most hydrogen solutions will have "A" as two terms.
hi, i would suggest to try to find the total charge of the whole atom with an integral of the density function over the region, then equal this to 0 (q=0,neutral atom) and probably you will come out with a condition (answer) for your constant A.
  • · Replies 22 ·
