Maxwell's equations and Coulomb's law
The discussion revolves around the relationship between Maxwell's equations and Coulomb's law, particularly in the context of electrostatics. Participants explore the implications of boundary conditions, uniqueness theorems, and the conditions under which these equations can be considered equivalent.
  • Some participants argue that Maxwell's first two equations in electrostatics can be seen as equivalent to Coulomb's law and the superposition principle, while questioning how they can be equivalent given the potential for infinitely many solutions.
  • Others assert that adding a gradient of a harmonic field does not satisfy the divergence equation, referencing a uniqueness theorem related to the equations.
  • A participant suggests that boundary conditions must be considered, as localized charge distributions have fields that tend to zero at infinity, which may not hold for harmonic functions.
  • There is a discussion about the uniqueness theorem and its dependence on boundary conditions, with some participants seeking clarification on these conditions for known charge distributions.
  • Some participants express uncertainty about how Maxwell's equations alone can determine the electric field without invoking Coulomb's law, particularly in cases with no symmetry.
  • There is a debate about whether the principle of superposition should be considered part of Coulomb's law and how this relates to the statements made by Feynman regarding the equivalence of the equations.
Participants do not reach a consensus on the equivalence of Maxwell's equations and Coulomb's law, with multiple competing views regarding the role of boundary conditions and the uniqueness of solutions. The discussion remains unresolved with ongoing questions and challenges to various claims.
Participants note that the uniqueness theorem is contingent upon appropriate boundary conditions, and there is uncertainty about what those conditions should be for specific charge distributions. The discussion highlights the limitations of Maxwell's equations in fully describing electrostatics without additional physical context.
kof9595995
In Feyman's lectures on physics, he said Maxwell's first 2 equations in electrostatics, namely curl E =0 and div E=rho/epsilon, is equivalent to Coulomb's law and superposition principle,
But for a particular charge distribution, we can always use Coulomb's law and superposition principle to determine one unique field, and when it comes to Maxwell's equation-if we just want to satisfy the 2 equations-we can add any gradient of a harmonic field to the field we get using Coulomb's law and superposition principle,thus we can get infinitely many solutions.
So how can it be that they are equivalent??
Adding a gradient won't satisfy the divE equation.
There is a uniqueness theorem for the divE and curlE dquations.
but I'm adding the gradient of a harmonic field,say, h, then laplacian h=0,which means
div(grad h)=0, then div(E+grad h)=div E+0=div E, which still satisfies the first equation.Am I correct?
"There is a uniqueness theorem for the divE and curlE equations. "
could you give some more details about the theorem? Thanks.
Any localized charge distribution has a field that tends to zero at infinity, while any harmonic function is not even bounded at infinity. One of the boundary conditions is violated, so the gradient of a harmonic function may not be added.
The uniqueness theorem depends on appropriate boundary conditions atyy suggests.
The proof is in most EM textbooks.
But what's the boundary condition for a known charge distribution?
I cannot see how Maxwell's equations require that "localized charge distribution has a field that tends to zero at infinity"
Knowing the charge (or current) distribution isn't enough to determine the electric field in the general case. Because electromagnetic waves can travel far from their sources, you could reasonably specify an incoming light wave at the boundary. In electrostatics, we assume there are no light waves by definition of statics, and the boundary conditions are set by eg. whether you have a conductor etc present.
Since the [itex]\nabla\times\vec{E}=0[/itex], we can ignore incoming and outgoing electromagnetic waves.
Choose some point as the center of a Gaussian Sphere of radius r so that all of the charge is contained within the sphere. Then the first of Maxwell's equations says, roughly, that:
[itex]\nabla \cdot\vec{E}=\frac{Q_{enc}}{\epsilon _0}\sim 4\pi r^2 |\vec{E}|[/itex]
Since the sphere is contains all of the charge, [itex]Q_{enc}[/itex] is constant, so that:
[itex]|\vec{E}|\sim \frac{Q_{enc}}{4\pi \epsilon _0r^2}\propto \frac{1}{r^2}[/itex]
So that the electric field tends to 0 at infinity. Another way to see this is through the multipole expansion, but I won't go into that right now.
but if we don't know the field is radical ,we cannot write E*4pi*r^2=Q/epsilon, right?
for example, in empty space there's a sphere (radius R) with a constant charge density rho, in electrostatics,then the electric field should be uniquely determined, but what's the boundary condition in this case?
That the field at infinity is zero.
but how do you know that without Column's law?I mean, just by Maxwell's equations.
You are correct that Max alone does not uniquely specify the E field, but you haven't understood the posts. Max + Boundary Conditions do uniquely specify the E field.
Yeah, I just cannot figure out what the boundary condition is in my example.
"That the field at infinity is zero. "
"but how do you know that without Column's law?I mean, just by Maxwell's equations. "
I just cannot figure out what the boundary condition is in my example, I don' understand where the condition "That the field at infinity is zero. " comes from.
In the case of a point charge, Gauss's law plus isotropy of space gives you Coulomb's law, from which you can see that the field goes to zero at infinity.
In the case of a charge distribution with no symmetry, it's hard to use Gauss's law, so one has to use "common sense" or "physical sense" to make the boundary condition at infinity the same as that of a superposition of point charges.
You can see that Maxwell's equations alone don't contain all the physics in classical electrostatics when a conductor is present. There we need "common/physical sense" to tell us that the conductor is equipotential. In some cases with a conductor, the boundary conditions plus uniqueness enables us to solve the problem with the "method of images" in which we solve the problem by replacing it with a different problem.
So the boundary conditions are determined by additional physics you choose according to the situation at hand, just like initial conditions.
But if we must take isotropy of space into account, does it mean divE= rho/epsilon and curlE=0 indeed say less than Column's law?
Hmm, yes and no. Do you count the principle of superposition as part of Coulomb's law?
Yes, but Feynman said divE= rho/epsilon and curlE=0 just "say no more and no less than" Column's law+superposition principle
RF oversimplified by leaving out the BC. He liked to make sweeping statements without too much care about the details.
Hmm, perhaps he should have left out "no more and no less". There's a web page with errata for the lectures, you can try sending your comments there.
  • · Replies 29 ·
