Need help correcting some problems
  • Thread starter Thread starter nns91
The discussion focuses on solving two physics problems involving torque and momentum conservation. In the first problem, the user calculated the moment of inertia of a wheel and the frictional torque, concluding with values of 7.96 kg*m² for the moment of inertia and 25 N*m for the frictional torque. In the second problem, the user attempted to apply conservation of energy and momentum principles to a system involving two blocks and a spring but arrived at incorrect velocity results. The user seeks assistance in identifying errors in their methods or calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with torque and angular acceleration concepts
  • Knowledge of conservation of momentum and energy principles
  • Ability to solve systems of equations in physics contexts
  • Review the calculation of angular acceleration and its application in torque equations
  • Study the relationship between torque, moment of inertia, and angular motion
  • Learn about the conservation of momentum in elastic and inelastic collisions
  • Examine the principles of energy conservation in mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of problem-solving in torque and momentum scenarios.
nns91
1. A wheel mounted on an axis that is not frictionless is initially at rest. A constant external torque of 50 N*m is applied to the wheel for 20s, giving the wheel an angular velocity of 600 rev/min. The external torque is then removed, and the wheel comes to rest 120s later. Find the moment of inertia of the wheel, and the frictional torque, which is assumed to be constant.
2.A 2kg block and an 8kg block are both attached to an ideal spring for which k=200 N/m and both are initially at rest on a horizontal frictionless surface. In an initial experiment a 0.1kg ball of clay is thrown at the 2kg block. The clay is moving horizontally with speed v when it hits and sticks to the block. The 8kg block is held still by a removable stop. As a result, the spring compresses a maximum distance of 0.4m.
In a second experiment, an identical ball of clay is thrown at another identical 2kg block, but this time the stop is removed so that the 8kg block is free to move.
e. State the principle(s) that can be used to calculate the velocity of the 8kg block at the instant that the spring regains its original length. Write the appropriate equation(s) and show the numerical substitutions, but do not solve for velocity.
[tex]\tau[/tex]=II*[tex]\alpha[/tex]
Ei=Ef
Pi=Pf
1. I found out the angular acceleration by using change in angular speed over change in time which is 3.14 rad/s^2
Then I set up the system of equation as [tex]\tau[/tex]friction= I*3.14 and 50-[tex]\tau[/tex]friction=5*3.14
Then I found out frictional torque is 25 N*m and I=7.96 kg*m^2
However, my result was wrong so can you guys help me spot out where did I do wrong and how to fix it ?
2.So I use conservation of energy and conservation of momentum.
For momentum I have
m(clay)*v(clay) + m(blocks)*v(blocks)= (m(clay)+2)+v(f,1) + 8*v(f,2)
I substitute numbers in as: 0.1*8.2= 2.1*v(f,1)+8*v(f,2)
For conservation of energy I have
(1/2)*0.1*8.2^2=(1/2)*2.1*v(f,1)^2+(1/2)*8*v(f,2)^2
I get 336.2=1.05*v(f,1)^2+4*v(f,2)^2
I set a system of equations containing two equations I just got and get
v(f,1)= -15.03 and v(f,2)= (8.2-2.1*-15.03)/8
Another wrong result. Anyone can spot out and help me fix the mistake ??
Thank you.
So do you guys think my methods were wrong or were that my calculations ?? I have not spotted the mistake yet. Anyone ?
  • · Replies 25 ·
12K
  • · Replies 17 ·
  • · Replies 33 ·
