Resonant Frequency of a tuning fork
The discussion revolves around determining the resonant frequencies of a tuning fork, specifically focusing on the two lowest frequencies for tines measuring 18 cm in length, with a wave speed of 420 m/s. Participants are exploring the implications of different boundary conditions on the resonant frequencies.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants discuss the application of wave equations and the relationship between wavelength and frequency, questioning the appropriateness of using certain formulas based on the physical setup of the tuning fork. There is confusion regarding the boundary conditions, particularly whether to consider nodes and antinodes at the ends of the tines.
Some participants have offered insights into the correct application of wave equations based on the node-antinode relationship, while others express uncertainty about the reasoning behind the frequency calculations presented in the original post. Multiple interpretations of the boundary conditions are being explored, reflecting a productive dialogue without explicit consensus.
Participants note the importance of understanding the fixed and free ends of the tines, which influences the resonant frequency calculations. There is acknowledgment of differing approaches to the problem, with some participants questioning the assumptions made in the original equations.
KYPOWERLIFTER
Name the two lowest resonant frequencies of a tuning fork; each tine is 18 cm long. Speed of wave is 420m/s... ignoring metal thickness.
F= Velocity/Wavelength; l= wavelength/2, l= wavelength, l= 3/2wavelength, l= 2wavelength, l= 5/2wavelength
fundamental = 420m/s / .72m = 583.3 Hz
first overtone = 420m/s / .36m = 1167 Hz
second overtone = 420m/s .24m = 1750 Hz
The given answer is 583 Hz
1750 Hz
2917 Hz
I would have expected to use the formulas wavelength/2, wavelength, 3/2wavelength. They have used, wavelength/2, 3/2wavelength, and 5/2wavelength. Is this because of the antinode-node boundary for each tine? I'm confused as to why they make the frequency jumps that they do. Very elementary physics and I am no student. So, I have no one to ask.
These equations aren't right. If [itex]L=\lambda/2[/itex] then it means that there is a node at both ends. But one end of the tine is free. So you must have a node at one end and an antinode at the other. Does that help?
Thanks for the reply... The equations are correct in the case of an antinode at each end. I took it that the book's writer must be working it that way, even though the fork has a node at the handle and two antinodes at the ends.
If he is basing it as if it's a node and an antinode then it would be [itex]L=\lambda/4[/itex], [itex]L=\3/4lambda[/itex], etc. This would be for two different wavea, though? One in each tine? That is to say, the 'L' would be 18cm? Twice? Even so, his method ofworking the problem does not compute that way, especially in light of:
I do not understand why he worked the problem by what seems to me is 'skipping' every other overtone?
Is my question clearly stated? Thanks, again
But you don't have an antinode at each end. One end of the tine is fixed.
Yup. Using the l=1/4(Lambda), l=3/4(Lambda), l=5/4(Lambda). Considering the system as a node-antinode relationship (which it clearly is), and thus employing .18m as the tine length, viola!
Thanks
9K
  • · Replies 33 ·
