| Thread Closed |
Simple Substitution Ciphers |
Share Thread | Thread Tools |
| Feb24-09, 05:48 AM | #1 |
Question: How many simple substitution ciphers are there where no point is fixed (ie: no letter is mapped to itself)? EDIT: Incase the termonoligy is different, a simple substitution cipher is a mapping where the plaintext in english is encoded so that every letter is mapped to a different letter. IE: a maps to Z b maps to S c maps to K etcetcetc thus abc plaintext is mapped to ZSK. 3. The attempt at a solution So, I did a few examples to see if I could get some insight into the problem: 1 Letter = 0 mappings 2 Letters = 1 mapping 3 Letters = 2 mappings 4 Letters = 9 mappings 5 Letters = 44 mappings I stopped here While I found the reason for the complexity of determining this number I didn't come across any way to do it in general for 26 letters (for English). I know it has to be above (n-1)! and below n! for n letters but other then that I'm unsure. I'm thinking I can just brute force it using algebraic notation, for example in the case of 4 letters I counted the mappings: 1 - 4cycle and with 4 letters there are 6 distinct combinations 2 - 2cycles and with 4 letters there are 3 distinct combinations But, with 26 letters the number of different cycle combinations becomes cumbersome. Any guidance would be appreciated. |
| Feb24-09, 06:26 AM | #2 |
Here's the way I would approach it: There are n! ways to permute n letters. But (n-1)! of them "fix" the first letter. Of the remaining, (n-2)! fix the second letter, of the remaining (n-3)! fix the third letter, etc. There are n!- ((n-1)!+ (n-2)!+ ...+ 2+ 1) permutations that do not fix any letter.
| Feb24-09, 01:35 PM | #3 |
I'm not sure I follow, when you say (n-1)! is the number of ways to fix the first letter does this allow more then the first letter to be fixed?
ie: For 5 letters 1 maps to 1 2 maps to 2 3 maps to 3 4 maps to 4 5 maps to 5 Would be counted in your (n-1)!. Now when you count the ways to fix the second letter I lose track of where you go. How did you count (n-2)! ways of fixing the second letter? |
| Feb24-09, 03:23 PM | #4 |
Recognitions:
That's a FUN problem. Try this. Call s(n) the number of cyphers containing n elements with no element fixed. Can you figure out a recursion formula to calculate s(n) assuming you know s(k) for k<n? If you have an (n-1)-cypher with no fixed elements how many ways can you extend it to an n-cypher with no fixed elements by just changing one element of the (n-1)-cypher? If you think harder about it you'll realize that this isn't all of the n-cyphers. You could also take an (n-1)-cypher with a single element fixed and change to an n-cypher. How many n-1-cyphers are there with a single element fixed? I haven't figured out how to 'sum' the resulting recursion relation and get to n=26 without computing all of the lower ones, though.
| Feb24-09, 05:52 PM | #5 |
Ok, I think I have my recursion formula.
S(n) = Number of maps with no fixed points and n letters Define: S(0) = 1 so the recursion looks nice, or consider it the empty mapping aCb = a choose b, ie: 26C2 = 325 S(n) = n! - ( nC1*S(n-1) + nC2*S(n-2) + nC3*S(n-3) + ... + nC(n-1)*S(1) + nCn*S(0) ) n! is the total mappings, nCi*(S-i) are the number of mappings with i fixed points. So is the next step to work out all of these for n=26? |
| Feb24-09, 06:03 PM | #6 |
Recognitions:
That's one way. Kind of a pain to do by hand. Easy if you've got a computer. If you think about the approach I outlined you can get an easier formula. S(n)=(n-1)*(S(n-1)+S(n-2)). That works nicely until the numbers start getting big. I turns out (I did some research) there is even a nonrecursive relation you can derive with inclusion-exclusion arguments. There's actually literature on this problem. A permutation with no fixed point is called a 'derangement'. Do they actually want you to calculate the number? It's got a lot of digits. Turns out it's very close to 26!/e, believe it or not.
| Feb24-09, 06:26 PM | #7 |
I see your extension idea, I was a little confused but now I think I understand. There are n-1 ways to extend S(n-1) into the range of S(n) but this means that any cycle including the new letter cannot be a 2-cycle ie: you need to also include extensions from one fixed point with n-1 letters. There are (n-1)S(n-2) mappings that you must add giving you (n-1)(S(n-1)+S(n-2)). I agree I like your formula better :P.
| Feb24-09, 10:07 PM | #8 |
Recognitions:
You're pretty good at this. Did you try an internet search for 'derangement'? It's actually pretty interesting. I liked the bit on mathworld where you can show the count is the incomplete gamma function of (n-1,-1) divided by e. And there's an even simpler recursion. S(n)=n*S(n-1)+(-1)^n. I haven't checked all the details on all of this, but there's more than one way to skin this cat. Your first recursion was actually the first one I figured out. Thanks for the diversion!
| Feb25-09, 03:42 PM | #9 |
I read the wikipedia and wolfram entries on it, I'm still working through the details on how they got their closed form (for n>=2) though I'm sidetracked as I want to keep up with the class I'm following independently in cryptography.
ie: Learning how to program some of the problems. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Simple Substitution Ciphers
| Simple Integration using U Substitution | Calculus & Beyond Homework | 13 | ||
| Simple Integration by substitution | Calculus & Beyond Homework | 9 | ||
| Simple differential equation substitution | Differential Equations | 8 | ||
| Simple Integration by Substitution | Calculus | 11 | ||
| How to solve an exponential ciphers? | Linear & Abstract Algebra | 3 | ||
