Lagrange equation problem involving disk
The discussion focuses on deriving Lagrange's equation for a system involving a uniform disk of mass M and radius a, which rolls along a rough horizontal rail while a particle of mass m is suspended from its center. The generalized coordinates are defined as x (horizontal displacement) and theta (angle of the string). It is established that x is a cyclic coordinate, leading to the conserved momentum p_x, which represents the horizontal linear momentum of the system. The period of small oscillations for the particle is derived as q√(3M/b).
  • Understanding of Lagrangian mechanics
  • Familiarity with cyclic coordinates and conserved momentum
  • Knowledge of small-angle approximations in trigonometry
  • Ability to formulate kinematic relations and constraints
  • Study Lagrange's equations in detail
  • Learn about cyclic coordinates and their implications in mechanics
  • Explore small oscillations and their mathematical derivations
  • Investigate kinematic relations in constrained systems
Students and professionals in physics, particularly those studying classical mechanics, as well as educators looking to enhance their understanding of Lagrangian dynamics and oscillatory motion.
pentazoid
A uniform disk of mass M and radius a can roll along a rough horizontal rail. A particle of mass m is suspended from the center C of the disk by a light inextensible string b. The whole system moves in a vertical plane through a rail. Take as generalized coordinates x, the horizontal displacement of C, and theta , the angle between the string and the downward vertical. Obtain Lagrange's equation . Show that x is a cyclic coordinate and find the corresponding conserved momentum p_x. Is p_x the horizontal linear momentum of the system?
Given that theta remains small in the motion , find the period of the small oscillations particle.
Ihave to “linearize” the θ equation, after eliminating derivitives
of x, to get an equation for θ that is effectively simple harmonic motion.
In this case, linearizing means assuming θ and ˙
θ are small, approximat-
ing all of the trigonometric functions up to terms linear in θ, and throwing
out terms quadratic in θ and ˙
θ. Soln.: the period for small oscillations is
q
3M b
x_1=q_1-F y_1=0 z_1=0
x_2=q_1+a*sin(q_2)-F,y_2=0,z_1=-a*cos(q_2)
Not sure what to do after that
What does it mean when it says, "The whole system moves in a vertical plane through a rail."? What is "through" about in this sentence?
You really did not show any relevant equations, and more importantly, you did not show an attempt at a solution. Yes, you wrote something under that heading, but it is awfully hard to understand what that means, and it looks more like some sort of final result, rather than a process for getting there.
To work this problem, you need to start with a good figure, identify the necessary coordinates, write the kinematic relatiions and the constraint relation(s), and then formulate your equations very carefully. The solution will be more than two lines long, I can assure you.
