Integration Problem with a Variable for an Upper Limit
The discussion revolves around an integration problem involving the function f(x) defined as the integral from 0 to x of the expression (1 / sqrt(t^3 + 2)). Participants are examining properties of this function and evaluating statements regarding its behavior at specific points.
  • Participants are exploring the implications of the function's positivity over a specific interval and questioning how this affects the values of f(x) at various points. There is also discussion about the necessity of integration to determine certain properties of the function.
The discussion is ongoing, with participants providing insights into the behavior of the function based on its graphical representation and properties. Some guidance has been offered regarding the relationship between the area under the curve and the positivity of the integral, but no consensus has been reached on all statements presented.
Participants are grappling with the implications of the function's behavior over the interval [-1, 1] and how this relates to the statements about f(x). There is a noted uncertainty regarding the integration of the function and its impact on the evaluation of the statements provided.
carlodelmundo
If f(x) = integration from 0 to x of ( 1 / sqrt [ (t^3) + 2] ) dt , which of the following is FALSE?
[tex] <br /> <br /> int({1}/{sqrt(t^3 + 2)},x=a..b)[/tex]
a.) f(0) = 0
b) f is continuous at x for all x >= 0
c) f(1) > 0
d) f'(1) = 1 / sqrt [3]
e) f(-1) > 0.
I know how to do a,b, and d. But how can I test for c and d if I don't know how to integrate such a weird function? I tried thinking of an arctan integration... but it looks "weird".
Thanks
You don't necessarily have to integrate a function to know something about it's values. For t in [-1,1], what is the sign of 1/sqrt(t^3+2)?
I can see that the graphof 1 / sqrt(t^3 + 2) from [-1,1] has a positive area. However, is this enough to prove that the integration is going to be positive?
I graphed the function... and when we take the integration from 0 to -1... will yield a negative error. Therefore, e) is wrong, correct?
Right. And, yes, if you have a positive area, the integral is positive. The integral measures area.
  • · Replies 105 ·
13K
  • · Replies 23 ·
