What is the orthogonal complement of W in C3 and how can its basis be found?
  • Thread starter Thread starter transgalactic
    Vector
The orthogonal complement of the subspace W, defined as W=span{v1=(1,0,i),v2=(2,1,1+i)}, in the complex space C3 is denoted as W⊥. This subspace consists of all vectors in C3 that are orthogonal to every vector in W. To find a basis for W⊥, one must solve the equations derived from the dot products of a vector u=(a,b,c) with v1 and v2, resulting in two equations with three unknowns. The solution yields a one-dimensional subspace, allowing for the normalization of the resulting vector to form an orthonormal basis.
  • Understanding of complex vector spaces, specifically C3.
  • Knowledge of linear algebra concepts such as span and orthogonality.
  • Familiarity with row reduction techniques for solving linear equations.
  • Ability to normalize vectors in a vector space.
  • Study the properties of orthogonal complements in vector spaces.
  • Learn about the Gram-Schmidt process for orthonormalization.
  • Explore the implications of dimensionality in subspaces of complex vector spaces.
  • Investigate applications of orthogonal complements in linear transformations.
Mathematicians, students of linear algebra, and anyone studying complex vector spaces and orthogonality in higher dimensions.
transgalactic
there is
find the orthonormal basis of
[tex] W^\perp [/tex]
i can do a row reduction and add another vector
which is independent to the other two.
so thy are othogonal.and then divide each coordinate of a given vector by the normal
of that vector
but what is
[tex]W^\perp[/tex] is the set of all vector in the space C3 orthogonal to every vector in W. It's easy to show it is also a subspace.
In order that a vector, u= (a, b, c), be orthogonal to every vector in W, it is sufficient that it be orthogonal to v1 and v2 and that is true as long as their dot products are 0:
(a, b, c).(1, 0, i)= a+ ci= 0 and (a,b,c).(2,1,1+i)= 2a+ b+ (1+i)c= 0. That gives you two equations in three unknowns. You can solve for two of the unknowns, say a and b, in terms of the other, c. "Normalize" the vector by choosing c so that its length is 1 and that will be your "orthonormal" basis. C3, the set of all ordered triples of complex numbers, has dimension 3. Since W has dimension 2, its "orthogonal complement" has dimension 1 so a basis consists of a single vector and you don't have to worry about the "ortho" part of orthonormal.
10K
  • · Replies 16 ·
14K
10K
