Solve Energy/Work Q: Mass .263 kg Dropped on Spring k=252 N/m Compresses 11.8 cm
  • Thread starter Thread starter vivekfan
The discussion focuses on a physics problem involving a mass of 0.263 kg dropped onto a spring with a spring constant of 252 N/m, which compresses the spring by 11.8 cm. The work done by gravity during compression is calculated as -0.304 J, while the work done by the spring is -1.75 J. The confusion arises regarding the initial potential energy (Pi) when calculating the speed of the block upon impact with the spring, where the teacher suggests using the negative work done by gravity instead of assuming Pi is zero.
  • Understanding of Hooke's Law and spring constants
  • Familiarity with work-energy principles in physics
  • Knowledge of gravitational potential energy calculations
  • Ability to apply conservation of energy concepts
  • Review the concept of Hooke's Law and its application in spring problems
  • Study the work-energy theorem and its implications in mechanical systems
  • Learn about gravitational potential energy and its role in energy conservation
  • Explore examples of energy conservation in systems involving springs and masses
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of spring-mass systems in action.
vivekfan
A mass of .263 kg is dropped on a spring with k=252 N/m. When it lands, it compresses the spring 11.8 cm. a) While the spring is being compressed, how much work is being done by gravity? b) What is the work done by the spring as it is being compressed? c) What is the speed of the block when it hits the spring?
W=Fdcos theta
W= -.5kx^2
deltaEmechanical=0
I got part a by using -(.263)(9.8)(.118)=-.304 J
I got part b by using W=-.5 (252)(-.118)^2=-1.75 J
I have a question for the third part.
I set up
(Kf+Pf)=(Ki +Pi)
(0+ .5kx^2)=(.5mv^2+ Pi)
I thought that Pi would be zero since it's all KE by the time it hits the spring, but my teacher solved the problem using the negative of the work done by gravity when the spring was being compressed. I am confused on why you use .304 J for Pi. Please explain.
Why the minus sign for part a?
I set up
(Kf+Pf)=(Ki +Pi)
This is a bit confusing since you don't specify spring PE versus gravitational PE. I would use:
Ki + gPEi + sPEi = Kf + gPEf + sPEf
The work done by gravity is positive, since both force (gravity) and displacement are in the same direction.
Another approach is to simply say:
KEf = KEi + work done.
Since you already figure out the work done in parts a and b, why not use it.
  • · Replies 58 ·
