What Forces Are at Play to Prevent Slippage Between Two Accelerating Boxes?
  • Thread starter Thread starter zeion
    Force Motion
The discussion revolves around a physics problem involving two boxes, where a smaller box rests on a larger box that is being accelerated horizontally. The focus is on understanding the forces at play that prevent the smaller box from slipping off the larger one, particularly the role of friction.
  • Participants explore the relationship between the applied force on the larger box and the frictional force that keeps the smaller box from slipping. Questions arise regarding the nature of friction and its dependence on normal force, as well as the conditions under which the boxes accelerate together.
The discussion is active, with participants seeking clarification on the concepts of friction and normal force. Some guidance has been provided regarding the proportionality of frictional forces to normal forces, but there remains uncertainty about how horizontal forces influence these relationships.
Participants express confusion about the definitions and relationships between forces, particularly in the context of horizontal acceleration and its effect on normal force. There is an emphasis on understanding the conditions necessary for the smaller box to remain stationary relative to the larger box during acceleration.
zeion
Top and bottom box force and motion question
Hello. This is my first time posting, I hope I have done everything correctly.
A small box is resting on a larger box, which in turn sits on a table. When a horizontal force is applied to the larger box, both boxes accelerate together. The small box does not slip on the larger box.
1) What force causes the small box to accelerate horizontally?
2) If the acceleration of the pair of boxes has a magnitude of 2.5 m/s[tex]^2[/tex], determine the smallest coefficient of friction between the boxes that will prevent slippage.
Horizontal Fa on the lower box causes the top box to move, but Fa cannot > Fs between the two boxes or top will slip. But if Fs between two boxes is > than Fa then bottom cannot accelerate therefore top will not accelerate. Therefore Fa = Fs.
Fa causes the top box to move, but Fs between top and bottom causes top to not slip.
2)
[tex]\mu_s = \frac{F_s}{F_n}[/tex]
It does not slip so [tex]F_A = F_s = ma[/tex]
There is not vertical movement so [tex]F_n = mg[/tex]
Therefore [tex]\mu_s = \frac{ma}{mg} = \frac{a}{g} = \frac{2.5m/s^2}{9.8m/s^2} = 0.25[/tex]
Welcome to PF.
It's really enough to say that the force of friction is a maximum proportional to the normal force that reacts against horizontal forces. So long as the system is not accelerating the top box greater than the maximum frictional force available, then it won't move.
LowlyPion said:
Welcome to PF.
Hi. Thank you.
So the force of friction is never greater than the horizontal forces, it can only either be less or equal to them, is that right? I don't understand how horizontal forces affect Fn, I thought Fn was proportional to the perpendicular forces ie. gravity, which is proportional to the object's mass.
zeion said:
Hi. Thank you.
Fn is just that. Weight down and supporting force up.
Frictional forces are calculated on the basis that their magnitudes can be determined by a proportionality relationship with the normal forces.
  • · Replies 97 ·
  • · Replies 19 ·
12K
