Potential Energy and Conservation of Energy Problem
The discussion revolves around a physics problem involving a pendulum with a 4.0 kg stone on a 3.2 m string, where the stone's speed is 7.7 m/s at its lowest point. The participants calculate the speed at a 62° angle to the vertical, determining it to be 5.10 m/s by applying the conservation of mechanical energy principles. They also establish that the total mechanical energy of the system is 118.58 J, with potential energy calculated using the height change derived from the cosine of the angle. The greatest angle reached by the pendulum occurs when kinetic energy equals zero.
  • Understanding of mechanical energy concepts, including kinetic energy (KE) and potential energy (PE).
  • Familiarity with the conservation of energy principle in physics.
  • Ability to perform trigonometric calculations, specifically using cosine for height determination.
  • Knowledge of basic pendulum motion and dynamics.
  • Study the principles of conservation of mechanical energy in different systems.
  • Learn how to calculate potential energy in gravitational fields using the formula PE = mgh.
  • Explore the relationship between speed and height in pendulum motion through further examples.
  • Investigate the effects of varying mass and string length on pendulum dynamics.
This discussion is beneficial for physics students, educators, and anyone interested in understanding pendulum mechanics and energy conservation principles in classical mechanics.
ChazyChazLive
A pendulum consists of a 4.0 kg stone swinging on a 3.2 m string of negligible mass. The stone has a speed of 7.7 m/s when it passes its lowest point.
(a) What is the speed when the string is at 62° to the vertical?
(b) What is the greatest angle with the vertical that the string will reach during the stone's motion?
(c) If the potential energy of the pendulum-Earth system is taken to be zero at the stone's lowest point, what is the total mechanical energy of the system?
I'm all confused >.< I figured there wold be max KE in the middle. Then there would be some KE & PE at the 62 degree part.. but idn what to do.. ugh I tried Ei = Ef so then Ei = .5mv2 but what would Ef be... idn.. i was thinking about centripetal force... idn I'm hopeless >.<
ME [Mechanical Energy] = KE [Kinetic Energy] + PE [Potential Energy]
At the stone's lowest point you could take the PE to be 0J (since it could be taken as the reference level); the KE at that point would then be the total mechanical energy of the system. At 62deg to the vertical, find the height above the reference level to solve for the PE. The difference between the ME and PE at that point is the KE. Then solve for the speed. The greatest angle would occur at the height where KE = 0.
hmm...
okie...
I was thinking of finding the height change, but I confuse myself sometimes. I couldn't figure out how to get it. So, you're supposed to do 3.2cos(62) = 1.502
And then do 3.2 - 1.502 = 1.698 which will equal the height change...
So now..
E (which equals the KE initial) = KE + PE
so plug in numbers 118.58 = (.5)(4)v^2 + (4)(9.8)(1.698)
v = 5.10 m/s
ooh yay! tehehe gots it!
and then basically work backwards for the angle
so E = mgh
and then for C.. it's just the E we've been working with
thankyou very much! ^_^ highly appreciated XD
