Find Mass Flow Rate: Formula & Explanation from a Rocket
The discussion revolves around the calculation of mass flow rate in the context of rocket propulsion. Participants explore various formulas and concepts related to mass flow rate, thrust equations, and the properties of propellants, with a focus on understanding the underlying variables and their definitions.
  • One participant expresses confusion about the formula for mass flow rate, suggesting \(\frac{dv}{dt}\) and providing a complex equation involving mass and velocity changes.
  • Another participant questions the definitions of variables in the proposed formulas, clarifying that mass flow rate is typically denoted as \(\dot{m}\) or \(\frac{dm}{dt}\), while volumetric flow rate is \(\frac{dV}{dt}\).
  • There is a suggestion that the thrust equation involves pressure differences and areas, with a participant proposing that \(q\) in the thrust equation should represent mass flow rate, despite it typically denoting volumetric flow rate.
  • A participant proposes a simplified formula for mass flow rate as \(\frac{m_f - m_i}{\Delta t}\), indicating that this would yield the average mass flow rate.
  • Another participant emphasizes the importance of knowing the propellant's molecular weight for accurate calculations and provides a link for further information.
  • There is a mention of specific propellant characteristics, such as optimum mixture ratios and adiabatic flame temperatures, in relation to mass flow rate calculations.
  • A question is raised about which formula to use for calculating mass flow rate, presenting two different equations for consideration.
Participants do not reach a consensus on the best formula for calculating mass flow rate, with multiple competing views and formulas being discussed. There is also uncertainty regarding the definitions of variables and their implications in the context of rocket propulsion.
Participants highlight the need for clarity on variable definitions and the dependence of mass flow rate calculations on the properties of the propellant. The discussion includes references to specific equations and their applications, but no resolution is reached regarding the most appropriate formula.
.:Endeavour:.
I want to clarify this because I'm still not sure how to find the mass flow rate, for instance from a rocket. I still puzzled from the formula that describes the mass flow rate which is [tex]\frac{dv}{dt}[/tex]. This the formula that I'm currently looking over but I'm not sure if its this formula to find the mass flow rate which is:
[tex] 0 = \frac{[(M - \Delta M)(v - \Delta v) + \Delta Mu] - Mv}{\Delta t}[/tex]
Then to find the thrust you use this equation:
Fthrust = [tex]qV_e + (P_e - P_a)A_e[/tex]
Where q is the rate of the ejected mass flow which I want to find out.
This is where I got the information: http://www.braeunig.us/space/propuls.htm
is there a little more definition of the variables used?
is v the final velocity and u the initial velocity? is M = mass? seems strange.
mass flowrate is mdot or dm/dt (ie. change in mass over change in time)
volumetric flowrate is dV/dt (ie. change in volume over change in time)
if v is velosity, then dv/dt is acceleration, so this is why I'm asking for your variable definitions.
obviously volumetric flowrate is density dependent and mass flowrate is not.
V=m/rho where rho is density.
The thrust equation is related to areas and pressures.
My guess would be:
Pe is pressure at nozzle exit
Pa is Pressure of atmosphere
Ae is cross-sectional area of rocket nozzle
F=PA in simple terms, so that half of the equation is right, but then for the firts term to hold, q would have to be mass flow rate. Usually q is volumetric flowrate, but fine.
Maybe a look at mass flow rates through orifices will help you understand it a bit better. Rocket nozzles are generally orifices with well designed entrances and exits. try: http://en.wikipedia.org/wiki/Orifice_plate
I think this might be another possibility:
[tex]\frac{m_f - m_i}{\Delta t}[/tex]
Ok, I read over the link that you send me and I found out that mass flow rate units are kg/s. So I think the you subtract mass final from mass initial and divided over the period of time. I'm not sure yet, but this is my assumption.
yes, this would give you the average mass flow rate. average change of mass (mf-mi) over time (delta t)
FredGarvin said:
Like was already mentioned, you still need to know something about the make up of the propellant, i.e. molecular weight.
Here's what you need:
http://www.grc.nasa.gov/WWW/K-12/airplane/mflchk.html
Yeah, that's the mass flow rate formula to find the flow rate. Yeah, this are the graphs that I'm looking at for the propellants that each have a unique Optimum Mixture Ratio, Adiabatic Flame Temperature, Gas Molecular Weight, and Gas Molecular Weight. I'm just looking over the Adiabatic Flame Temperature for Kerosene LO2, LH2 and LO2, and also Dinitrogen Tetroxide & Aerozine 50. The area that the formula gives, is it for neck of the engine?
At is the throat area.
When you are going to calculate the mass flow rate, which formula do you use? Do you use:
[tex]mdot = \frac{A p_t}{\sqrt{T_t}} * \sqrt{\frac{\gamma}{R}} * M (1 + \frac{\gamma - 1}{2} M^2)[/tex][tex]^-^\frac{\gamma + 1}{2(\gamma - 1)}[/tex]
or mdot = r*V*A?
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 18 ·
