| Thread Closed |
Power and heaters |
Share Thread | Thread Tools |
| Mar2-09, 07:48 AM | #1 |
Power and heaters
A heater rated at 2000W operating at 250V is used on a supple of 230V. if the resistance of the heater will not be affected by temp, what is the power absorbed by the heater? 2. Relevant equations i think that the only equation to use will be P=V^2/R 3. The attempt at a solution because the resistance of the heater is its internal property, i would first compute for the resistance from: R=(230^2)/2000. afterwhich, i would compute the power absorbed by the heater through: V=250-230=20 -> P = (20^2)/R which will be computed from the previous equation. is this right? thanks! |
| Mar2-09, 07:57 AM | #2 |
Mentor
| Mar2-09, 08:20 AM | #3 |
so, the power when it operates at 230V is simply P= 230^2/R and the answer I would subtract from 2000W? is it right? thanks |
| Mar2-09, 08:28 AM | #4 |
Mentor
Power and heatersP= 230^2/R... and that's the final answer. |
| Mar2-09, 09:01 AM | #5 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Power and heaters
| A question about DC motor (input power, output power) | General Physics | 3 | ||
| Early power analysis with CPF - A PRACTICAL GUIDE TO LOW-POWER DESIGN | Electrical Engineering | 0 | ||
| Explain Why Wind Power Works But Permanent Magnet Power Doesn't | General Physics | 10 | ||
| Do light bulbs or convection heaters heat a room with the highest efficiency? | General Physics | 13 | ||
| Heaters | Introductory Physics Homework | 1 | ||
