Thread Closed
Linear Algebra: Linear Combinations
Share Thread Thread Tools
Mar3-09, 12:46 AM   #1
Let V = {f: [tex]\mathbb {R}\rightarrow\mathbb {R}[/tex]} be the vector space of functions. Are f1 = ex, f2 = e-x (both [tex]\in[/tex] V) linearly independent?
2. Relevant equations
0 = aex + be-x Does a = b = 0?
3. The attempt at a solution
My first try, I put a = e-x and b = -ex. He handed it back and told me to try again. I think the problem was that my a and b were not constants. But how to prove that there are no constants that will make the equation 0? I wrote some stuff down about the fact that, if a=0, then b = 0 (and the converse). Is that sufficient or am I way off?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar3-09, 01:04 AM   #2
Recognitions:
Homework Helper Homework Help
One way to do it would be a proof by contradiction.
Suppose there are constants, not both 0, a and b, such that aexp(x) + bexp(-x) = 0 for all x. Then aexp(x) = -bexp(-x), so -a/b * exp(2x) = 1 for all x. I won't complete it for you, but look at x=0, and see what restriction it places on a/b. Then look at a different point and you will reach a contradiction. (Also note, I've implicitly assumed b is nonzero, so you should handle that case as well)
Mar3-09, 01:07 AM   #3
Recognitions:
how about
a.ex+b.e-x = 0
multiply by e-x
a.e2x+b = 0
this is not true in general for all x in the reals unless a=b=0
Mar3-09, 09:55 AM   #4
Mentor
Quote by lockedup View Post
Yes, a = b = 0 is one solution, and is always a solution regardless of whether these functions are linearly dependent or linearly independent. The real question is whether this solution, the trivial solution, is the only solution. If so, the functions are linearly independent. If not, they are linearly dependent.
Thread Closed
Thread Tools
Similar Threads for: Linear Algebra: Linear Combinations
Thread Forum Replies
Linear algebra (impact of solution of theory of linear equations) Calculus & Beyond Homework 2
Linear Algebra - Linear Constant Coefficient Difference Equations Calculus & Beyond Homework 3
[SOLVED] linear algebra - inner product and linear transformation question Calculus & Beyond Homework 0
Linear Algebra: Linear Transformation and Linear Independence Calculus & Beyond Homework 8
LINEAR ALGEBRA - Describe the kernel of a linear transformation GEOMETRICALLY Calculus & Beyond Homework 6
