Represent on a diagram the following to vectors
  • Thread starter Thread starter undertow2005
    Diagram Vectors
The problem involves representing two vectors on a diagram: one vector of 3m at 45 degrees north of east and another vector of 6m at 60 degrees west of north. The focus is on finding the resultant of these two vectors in terms of magnitude and angle with respect to the east.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the correct component breakdown of the vectors based on their reference directions. There is an emphasis on ensuring both vectors are referenced to the same principle direction before summing them.
Some participants have provided feedback on the original poster's calculations, pointing out issues with the reference directions and the need to adjust angles accordingly. There is ongoing clarification regarding the correct use of trigonometric functions for the second vector.
Participants note the importance of understanding the reference directions for each vector and the implications this has on the calculations. There is also mention of potential mistakes in interpreting angles and signs in trigonometric functions.
undertow2005
heres the problem
represent on a diagram the following to vectors:1) 3m, 45 degrees north of east; and 2) 6m, 60 deg west of north. find the resultant of sum of these two vectorsin terms of magnitude and angle with respect to the east.
nevermind the first part of the Q, i need to find the second part
my incorrect solution:
for vector one:
Cx=3m*cos45=2.121
Cy=3*sin45=2.121
Vector 1=2.121i + 2.121j
Vector two:
Cx=6*cos60=3
Cy=6*sin60=5.196
vector 2= 3i +5.196
i added them and got this 5.121i +7.317j
someone check!
My Final only two hours away!
You've got the mechanics of it down, but you're not paying enough attention to your principle directions. These vectors aren't referenced to the same principle direction.
The first is referenced to East - your components were correct.
The second is referenced to North - you need to add 90 degrees to the angle to convert it to an East reference (you also made a mistake by using positive 60, which is 60 degrees East of North, but that's irrelevant since you started from the wrong reference).
The 'i' of your second vector is the cosine of 150 degrees - the 'j' the sine of 150 degrees. (the cosine of 150 is negative, meaning your resultant will be a positive plus a negative).
vector 2
6*cos(-150=-5.196
6*sin(-150=-3.00
correct?
Almost. Sine of 150 is positive one-half (+0.5).
Sine is positive from 0 to 180
Cosine is positive from 270 to 90
If you plot this on a graph, your cosine is your x and your sine is your y, which makes it pretty easy to see which quadrants are positive or negative.
